Staro 20.04.2015., 19:54   #1
buljaka
Datum registracije: Aug 2014
Postovi: 2,938
cudan problem sa mrezom - velik ping i spor net - mobitel zagusivao mrezu
Cisto ako nekome pomogne moje iskustvo...
Naime vec 2 tjedna dana mucim muku sa povremeno sporim netom, ping ode u svemir, cs go ne mogu ni igrati, pa restiram modem pa bude ok par dana pa onda opet
sve zivo sam probao, prikljucivao komp jedan po jedan i analizirao pakete, nista ne gusi sa uploadom
iskljucio sam nas sa mreze misleci da on pravi sranja, no nije
danima vec bude samo po jedan komp + mobiteli na mrezi
na mobitelima pogasio uploade tipa google +, dropbox i sl
testiram vezu, sve super, sutra opet krenu problemi
npr
C:\Users\Dnevna>ping www.google.com
Pinging www.google.com [74.125.195.105] with 32 bytes
Reply from 74.125.195.105: bytes=32 time=2258ms TTL=47
Reply from 74.125.195.105: bytes=32 time=2652ms TTL=47
Reply from 74.125.195.105: bytes=32 time=3219ms TTL=47
Request timed out.
Ping statistics for 74.125.195.105:
Packets: Sent = 4, Received = 3, Lost = 1 (25% los
Approximate round trip times in milli-seconds:
Minimum = 2258ms, Maximum = 3219ms, Average = 2709
Pinging www.google.com [173.194.122.20] with 32 bytes
Reply from 173.194.122.20: bytes=32 time=635ms TTL=49
Reply from 173.194.122.20: bytes=32 time=1005ms TTL=49
Reply from 173.194.122.20: bytes=32 time=1482ms TTL=49
Reply from 173.194.122.20: bytes=32 time=2137ms TTL=49
Ping statistics for 173.194.122.20:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss
Minimum = 635ms, Maximum = 2137ms, Average = 1314m
Request timed out.
Reply from 173.194.122.20: bytes=32 time=3473ms TTL=49
Reply from 173.194.122.20: bytes=32 time=938ms TTL=49
Reply from 173.194.122.20: bytes=32 time=63ms TTL=49
Minimum = 63ms, Maximum = 3473ms, Average = 1491ms
Reply from 173.194.122.20: bytes=32 time=903ms TTL=49
Reply from 173.194.122.20: bytes=32 time=1409ms TTL=49
Reply from 173.194.122.20: bytes=32 time=2092ms TTL=49
Reply from 173.194.122.20: bytes=32 time=2998ms TTL=49
ping u cs go ode na 1700 npr
promijenio wep u wpa, promijenio password, nema neautoriziranih uredjaja
promijenio i ssid i sakrio ga
jucer promijenim modem misleci da je on
i danas opet isti k...
bio tehnicar, sve je ok sa vezom
i danas slucajno skuzim da sestrin htc one x koji boluje od onog poznatog one x wifi buga sa losim signalom zagusuje cijeli net kada se spoji . ali random totalno. ne radi sinhronizacija NICEGA, sve iskljuceno a ping svakih 10tak minuta ode u nebesa
ping bez njega
Pinging www.google.com [74.125.195.99] with 32 bytes o
Reply from 74.125.195.99: bytes=32 time=64ms TTL=47
Reply from 74.125.195.99: bytes=32 time=54ms TTL=47
Reply from 74.125.195.99: bytes=32 time=53ms TTL=47
Ping statistics for 74.125.195.99:
i onda nadjem na xda da wifi radio na njenom mobu ima nekakav bug da napravi wifi hog povremeno, a njen ocito cesce sad vise nema sifru za wifi i sve je ok
