Staro 18.10.2005., 19:23   #1
Brain32
Brain32's Avatar
Postovi: 498
Forceware v81.85(za one sa 7-icama)
Win32: http://downloads.guru3d.com/download.php?id=10
Win64: http://downloads.guru3d.com/download.php?id=28
Release notes:
Single GPU Issues Resolved
• GeForce 7800 GT/GTX: Soft shadows in FEAR are not rendered
correctly.
• GeForce 7800 GT/GTX: The system crashes after a minute or so of
playing Half-Life 2: Lost Coast.
• GeForce 7800 GT/GTX: The Apple 30ʺ panel display splits into four
grids at 800x600, 1024x768, and 1600x900 resolutions.
• GeForce 7800 GT/GTX: Application performance drops when
Gamma Antialiasing is enabled.
• GeForce 7800 GTX, SLI: With SLI mode enabled, the mouse cursor
image occasionally sticks as the window resize graphic instead of
being restored to the pointer graphic.
• GeForce 7800 GTX SLI: Resuming from system Hibernate results in a
corrupt or distorted desktop.
• GeForce 7800 GT/GTX: F.E.A.R demo - The system hangs when
entering room with volumetric lighting.
• GeForce 7800 GTX: Random pixels appear during gameplay in
F.E.A.R.
• GeForce 7800 GTX / GeForce 6800 Ultra/ GeForce 6600: There is
intermittent glowing corruption around the edges of the screen in Far
Cry patch 1.33 when HDR is enabled.
This has been partially fixed in driver version 81.85. An upcoming patch for
Far Cry fixes the issue completely.
• GeForce 6 Series: With the latest FarCry patch, the application profile
breaks the HDR functionality.
This has been partially fixed in driver version 81.85. An upcomng patch for
• GeForce 6800 Ultra: The system hangs when running 3D applications
on a x16 PCI-E system.
Ima poboljsanja i za nas "jadnike" s 6-icama ali 7-ica je u prvom planu ovih drivera
Brain32 je offline   Reply With Quote
Staro 19.10.2005., 12:53   #2
Cali
H2TB
Cali's Avatar
Postovi: 363
sa ovim driverima sam dobio oko 200 3d marka 03 više. cool!!!
Cali je offline   Reply With Quote
Staro 19.10.2005., 13:47   #3
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
Dobio sam dodatnih 100 FPS u OGame i NavyField, yeeeaaah they kick arse
Skinut cu cim DSL proradi
Staro 19.10.2005., 14:00   #4
MRKONJA
M.U.P.
MRKONJA's Avatar
Datum registracije: Sep 2004
Postovi: 2,277
Ja sam mislio da samo ja imam problema
MRKONJA je offline   Reply With Quote
Staro 19.10.2005., 14:50   #5
Brain32
Brain32's Avatar
Postovi: 498
Da to svi nest briju, navodno da taj novi driver "trosi" manje CPU-a pa je odmah lakse za zvucnu i ostalo te da je zato ukupni framerate u igrama bolji. Uglavnom na guru3d su svi jako zadovoljni, dobre performanse i nema bug-ova...
Staro 19.10.2005., 23:43   #6
Cali
H2TB
Cali's Avatar
Postovi: 363
a slušajte, ja izmjerio i stvarno više sam dobio na defaultu...
Staro 20.10.2005., 00:37   #7
Brain32
Brain32's Avatar
Postovi: 498
Kakvom "defaultu":confused:
Staro 20.10.2005., 02:22   #8
Cali
H2TB
Cali's Avatar
Postovi: 363
govorim o 3d marku 03 na default postavkama (1024*768, bez AA)
Staro 21.10.2005., 00:15   #9
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
novi driveri su super ono stvarno super,u call of dutyu2 sam dobio negdje 5 fpsova više što je super za tu igru kad znamo da radi na 30fps na 7800GTX znači igra mi se vrti preko 20fps što je super,mislim na onaj demo,SS2 isto radi za 20 frameova više ono super ajd konačno dobri driveri
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 21.10.2005., 08:05   #10
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Jedino što sam ja dobio od novih drivera je Microsoft Error Report
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 21.10.2005., 10:41   #11
Chome
TK
Chome's Avatar
Postovi: 1,092
kako tako malo fps-a?? Na kojim postavkama je to?
Chome je offline   Reply With Quote
Staro 21.10.2005., 11:37   #12
Lihto
Lihto's Avatar
Postovi: 3,945
1280*1024
iPhone XR 128gb
Staro 21.10.2005., 19:39   #13
Chome
TK
Chome's Avatar
Postovi: 1,092
Pa to je poprilično ja inače sve igram na 1024x768 jer imam 17'' CRT samsungov pa mi je to normalna rezolucija na desktopu pa tako i u igrama.
Staro 21.10.2005., 20:08   #14
Lihto
Lihto's Avatar
Postovi: 3,945
ja imam lcd pa zato
iPhone XR 128gb
Staro 21.10.2005., 20:13   #15
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Je, COD II daje malo čudne rezultate, što se FPS-a tiče. Meni na istoj rezi (1280*1024) s uključenim 4xAA i 8xAF daje oko 24, s pado do 17-18, a igra ne trza u nijednom trenutku.
Staro 21.10.2005., 23:26   #16
Lihto
Lihto's Avatar
Postovi: 3,945
da to je ono najsmješnije radi na 15fps a ne šteka baš čudno,al ipak je to demo vidjet ćemo oće li optimizirat bolje igru prije nego ju pošalju na umnožavanje
iPhone XR 128gb
