Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,568
(riješeno) PCI data acquisition and signal processing controller problemi
PCI data acquisition and signal processing controller dakle od prvog dana kada imam ovu ploču. Na Asus ROG forumu su mi rekli da sam vjerovatno zaboravio instalirati Intel MEI a ja jesam. Al aj udrio sam Repair. Jedno duže vrijeme sam mislio da mi tipkovnica čini taj problem pa sam mislio da je promjenim. Sada sam probao s nekom starom PS2 tipkovnicom čak sam i deinstalirao webcam koja je imala moddani driver da radi u 7 x64. I samo samo problemi s ovim PCI data acquisition and signal processing controller. Većinom puta radi ok par sati čak ponekad i dana(da se uvjerim da je sve ok stiskao sam Scan u device manageru). Ponekad nakon bootanja u Windowse odmah iskoči u device manageru a ponekad treba čekat po par sati. Sistem radi stabilno bio on OCan ili ne. Više neznam što da radim. EDIT Neki kažu da je to dio AMDA00 sučelja za one Asus 5 way pa cu probat. Također u Event Vieweru samo jednom se dogodi ovaj error prilikom bootanja Windowsa. The driver \Driver\WUDFRd failed to load for the device ACPI\PNP0A0A\2&daba3ff&2. EDIT#2 Na Asus ROG forumu su mi dali ovako pojašnjenje. "a) Those WUDFRd errors are not ACPI errors. No matter if they point to ACPI\PNP0A0A\2&daba3ff&2. This is just a PNP (Plug and Play) indentifier that points to a device class. b) WUDFRd is Windows User Mode Driver Framework. This is a framework for drivers that run in user mode, in contrast to kernel mode that most drivers run as. These are drivers that do not need Ring-0 security layer access for those familiar with technical details. For the rest it's too complicated to explain. c) Those errors happen because of bugs in Windows and specifically the Framework itself. WUDFRd is not available when Windows tries to load the driver so you get these errors in the event viewer. Afterwards the driver for the device is loaded normally, if it wasn't then the device that uses WUDFRd (eg your Android phone) would not work (would not be seen by your PC). These errors can be safely ignored untill Microsoft decides to fix those issues. You will usually see these errors when devices that use WUDFRd are connected during boot/reboot. In case of software using a user mode driver, you will see these errors always if the driver get initiated on boot (so yes it's possible to see these errors caused by software BUT again they are harmless). d) Lastly, the original error you are reporting is entirely unrelated to the WUDFRd errors you are seeing and is most likely cause by bad driver, operating system corruption, bad RAM or even a combination of those." EDIT#3 Reinstalacijom Chipset Drivera "PCI data acquisition and signal processing controller" nestane ali se vrati svako nekoliko sati. Više neznam što da radim. Zadnje izmijenjeno od: Karlo666. 10.02.2015. u 11:12. |
