Staro 13.10.2005., 15:17   #1
kony
bacc. ing. comp.
Postovi: 310
PENTIUM 64-bit KONFIGURACIJA do 5300 kn
Samsung SM997MB 19" FLAT CRT, 0.20D/P, H(30-96kHz), P(250MHz), 1920x1440@64Hz, 1600x1200@75Hz, Highlight III, MB II, MouScreen, BNC, TCO'03, LH19ISBBS
MB GIGABYTE 8IPE775-G, s775, Intel 865PE, FSB 800/533, Serial ATA, UDMA133, 5PCI, AGP8x, 4DDR (Dual channel 400/333/266MHz), 8-channel sound, Gigabit LAN, USB 2.0, HT, ATX
CPU INTEL PENTIUM4 630 (3.0 GHz, 800 MHz, 2MB), 64-bit, Socket 775, BOX, Prescott
DDR 512 MB 184 pin, PC3200, 400MHz, A-Data, V-Data
*HDD HITACHI HDS722580VLSA80 80GB SATA 7200rpm 8MB
Sapphire ATI Radeon 9600Pro Advantage 128MB DDR, TV-Out,
DVI-Out
CODEGEN midi tower 6044L-C10, 400W, P4, USB+FAN,audio, srebrna; 495x182x425; 5.25"x4, 3.5"x2, 3.5" (hidden)x5
5247 kn s pdv
kaj mislite o konfiruraciji s obzirom da su sredstva ogranicena...
kony je offline   Reply With Quote
Staro 13.10.2005., 18:28   #2
E.T.
E.T.'s Avatar
Postovi: 2,458
Solidno makar je ta kombinacija kuciste+napajanje losa, odnosno bolje bi bilo uzeti neko kvalitetnije napajanje.
Nisi napisao koja je namjera no mozda nebi bilo lose da razmislis o AMD-u nesto ovog tipa:
-AMD64 3000+BOX
1200Kn (Bing)
-MBO MSI K8N NEO4 FI, nForce4ULTRA, g-lan, s-ata, pci-e, s. 939
736Kn (Bing)
-DDR 512 MB 184 pin, PC3200, 400MHz, A-Data, V-Data
367Kn (Ve-mil)
-Sapphire Radeon X550 Advantage PCIE, 128M DDR, TV-out, DVI, Lite Retail
559Kn (Ve-mil)
-HDD HITACHI HDS728080PLA380 80GB SATA300 7200rpm 8MB
436Kn (Ve-mil)
-Napajanje CHIEFTEC 410W, 12cm vent., ATX2 ver 2.0
341Kn (Links)
-Case po izboru do 300Kn
-Mon. Samsung SM997MB 19'' DynaFlat
1453Kn (Ve-mil)
UK=5392Kn
S AMD-om dobijes slicne perfomanse no bolje napajane i kuciste te u potpunosti novu platformu (64bit, PCI-E)...nekako mi se cini lose sada kupovati Intel konfiguraciju bez DDR2 i PCI-e...
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 13.10.2005., 20:46   #3
kony
bacc. ing. comp.
Postovi: 310
necu amd do sam sam imao AMD i nisam zadovoljan,nije da kuham vatru....
Staro 13.10.2005., 21:07   #4
ZED
a.k.a. LOPOV
ZED's Avatar
Postovi: 2,022
Imas li neki određeni razlog za agp plocom?
Ako ne zemi neku sa 915 ili 925 chipsetom
Zabranjene reklama u sigu.
Staro 14.10.2005., 15:00   #5
kony
bacc. ing. comp.
Postovi: 310
ok samo mi recite koju od ove dvije ploce su bolje jel jedino te mogu kupit....
MB Gigabyte 8I915P-G
Gigabyte 8I915P Duo
ploče na www.ve-mil.hr
www.m-computers.hr
Staro 14.10.2005., 15:21   #6
kony
bacc. ing. comp.
Postovi: 310
Samsung SM997MB 19" FLAT CRT, 0.20D/P, H(30-96kHz), P(250MHz), 1920x1440@64Hz, 1600x1200@75Hz, Highlight III, MB II, MouScreen, BNC, TCO'03, LH19ISBBS 1.178,10 kn 1.178,10 kn obriši
MB GIGABYTE 8I915P Duo, s775, Intel 915P, FSB 800/533, 4xSerial ATA, 1xUDMA100, 2xUDMA133 RAID, 3PCI, 2PCI-E x 1, 1PCI-E x 16, 2DDR II + 2DDR (Dual channel), 8-channel Intel High Definition audio, Gigabit LAN, USB 2.0, HT, ATX 573,38 kn 573,38 kn obriši
CPU INTEL PENTIUM4 630 (3.0 GHz, 800 MHz, 2MB), 64-bit, Socket 775, BOX, Prescott 1.198,04 kn 1.198,04 kn obriši
DDR2 512MB 240 pin, PC4200 (533MHz), Super Talent 336,29 kn 336,29 kn obriši
*HDD HITACHI HDS722580VLSA80 80GB SATA 7200rpm 8MB Akcija! 362,48 kn 362,48 kn obriši
GIGABYTE Radeon X600Pro 128MB DDR, TV-out, DVI-out, PCI-X, bulk 486,63 kn 486,63 kn obriši
CODEGEN midi tower 6044L-C10, 400W, P4, USB+FAN,audio, srebrna; 495x182x425; 5.25"x4, 3.5"x2, 3.5" (hidden)x5 205,82 kn 205,82 kn
evo ispravio sam konfiguraciju
ja mislim da je sa konfa ok....
