Staro 22.06.2014., 15:10   #1
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,120
Question (riješeno) BSOD 0x50 Windows 8.1U1
Code:
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 9600.17085.amd64fre.winblue_gdr.140330-1035
Machine Name:
Kernel base = 0xfffff800`0887a000 PsLoadedModuleList = 0xfffff800`08b442d0
Debug session time: Sat Jun 21 09:54:23.865 2014 (UTC - 4:00)
System Uptime: 0 days 0:01:31.773
*                        Bugcheck Analysis                                    *
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffff96001431220, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff960001b91dc, If non-zero, the instruction address which referenced the bad memory
	address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
Could not read faulting driver name
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
READ_ADDRESS: fffff80008b31ce0: Unable to get special pool info
unable to get nt!MmNonPagedPoolStart
unable to get nt!MmSizeOfNonPagedPoolInBytes
 fffff96001431220
FAULTING_IP:
win32k!bPEBCacheHandle+9c
fffff960`001b91dc 428b94b9a0f53500 mov     edx,dword ptr [rcx+r15*4+35F5A0h]
MM_INTERNAL_CODE:  2
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
BUGCHECK_STR:  AV
PROCESS_NAME:  explorer.exe
CURRENT_IRQL:  0
TRAP_FRAME:  ffffd001ff8ea820 -- (.trap 0xffffd001ff8ea820)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=fffff960001ad000
rdx=00000000003c9320 rsi=0000000000000000 rdi=0000000000000000
rip=fffff960001b91dc rsp=ffffd001ff8ea9b0 rbp=ffffd001ff8eaab9
 r8=0000000000b00f48  r9=fffff90140219b10 r10=0000000000001362
r11=7ffffffffffffffc r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei pl zr na po nc
win32k!bPEBCacheHandle+0x9c:
fffff960`001b91dc 428b94b9a0f53500 mov     edx,dword ptr [rcx+r15*4+35F5A0h] ds:fffff960`0050c5a0=0000000a
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff800089ff24a to fffff800089cdfa0
STACK_TEXT:
ffffd001`ff8ea638 fffff800`089ff24a : 00000000`00000050 fffff960`01431220 00000000`00000000 ffffd001`ff8ea820 : nt!KeBugCheckEx
ffffd001`ff8ea640 fffff800`088e19c9 : 00000000`00000000 ffffe000`3d77b080 ffffd001`ff8ea820 0000001c`00000084 : nt! ?? ::FNODOBFM::`string'+0x20d9a
ffffd001`ff8ea6e0 fffff800`089d822f : 00000000`00000000 fffff901`40219b10 00000000`00000000 ffffd001`ff8ea820 : nt!MmAccessFault+0x7a9
ffffd001`ff8ea820 fffff960`001b91dc : 00000000`00000000 00000764`00000000 00000000`00000000 fffff901`407d3c60 : nt!KiPageFault+0x12f
ffffd001`ff8ea9b0 fffff960`001fb5bb : 00000000`76040676 00000000`00000000 00000000`00007604 fffff901`40219b10 : win32k!bPEBCacheHandle+0x9c
ffffd001`ff8eaa20 fffff960`001b97b0 : fffff901`407ab700 fffff960`001e5c49 00000000`00000010 fffff901`422afe20 : win32k!NtGdiDeleteObjectApp+0x12b
ffffd001`ff8eab20 fffff960`002050e5 : 00000000`00000000 00000000`00000007 ffffe000`3c931e60 00000000`00000000 : win32k!NtGdiFlushUserBatch+0x4b0
ffffd001`ff8eadb0 fffff800`08c58e1e : 00000000`00000001 00000000`00000000 00000000`00000007 00000000`76040676 : win32k!W32CalloutDispatch+0x297
ffffd001`ff8eae00 fffff800`089d96c7 : 00000000`00000001 fffff960`002e7f70 00000000`00000020 fffff901`4069c170 : nt!PsInvokeWin32Callout+0x42
ffffd001`ff8eae40 00007ffa`c7fb2b5a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceGdiTebAccess+0x33
00000000`029feac8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7ffa`c7fb2b5a
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  4
SYMBOL_NAME:  win32k!bPEBCacheHandle+9c
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: win32k
IMAGE_NAME:  win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  53416011
FAILURE_BUCKET_ID:  X64_AV_win32k!bPEBCacheHandle+9c
Followup: MachineOwner
Meni ovo iskreno malo znači, koliko vidim explorer.exe je kriv kao i neki driver kaj mi baš i nema smisla
Unaprijed hvala!
Pozdrav,
neki puta mi se pojavi BSOD prilikom paljenja laptopa. Na njemu su svježe instalirani Windowsi.
BSOD se dogodi dosta rijetko i bez nekog normalnog patterna pa mi nije jasno zakaj se uopće događa
Code:
Machine Name:
Arguments:
	address.
Debugging Details:
 fffff96001431220
FAULTING_IP:
MM_INTERNAL_CODE:  2
BUGCHECK_STR:  AV
CURRENT_IRQL:  0
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
MODULE_NAME: win32k
Unaprijed hvala!
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 22.06.2014., 15:28   #2
MMI
MMI's Avatar
Postovi: 913
video driver? nešto vezano uz ram na vga ili sistemski ram..
MMI je offline   Reply With Quote
Staro 24.06.2014., 21:50   #3
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,120
Reinstalacija Windowsa je pomogla, namjerno sam postavio sve apsolutno isto i sad je ok
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
