Povratak   PC Ekspert Forum > Računala > Software > Web dizajn, programiranje i ostalo
Staro 10.06.2014., 15:30   #1
Falcon11
Datum registracije: Apr 2014
Postovi: 8
C# MDI tekstualni editor
Pozz ekipa !
Radim MDI tekstualni editor i trebam napraviti find dialog box za pronalaženje stringa. Form1 mi ima toolbar, a Form2 richtextbox. Find dialog box sam riješio tako da sam dodao novu formu Form3. Međutim program mi uvijek vraća da string nije pronađen. Evo kod pa ako neko zna ne bi škodila pomoć
Form1
Code:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.IO;
using System.Windows;
using Microsoft.Win32;
namespace proba_4
    public partial class Form1 : Form
        String path = "";
        int broj = 1;
        public Form1()
            InitializeComponent();
        public Form1(string text)
        private void newToolStripMenuItem_Click(object sender, EventArgs e)
            Form2 f2 = new Form2();
            f2.MdiParent = this;
            f2.Text = "bilješka" + broj;
            f2.Show();
            broj++;
        private void openToolStripMenuItem_Click(object sender, EventArgs e)
            OpenFileDialog openFileDialog1 = new OpenFileDialog();
            openFileDialog1.Title = "Open";
            openFileDialog1.Filter = "Text Files(*.txt)|*.txt|All Files(*.*)|*.*";
            DialogResult saveResult = openFileDialog1.ShowDialog();
            if (saveResult == DialogResult.OK)
                try
                    Form2 f2 = new Form2(File.ReadAllText(openFileDialog1.FileName));
                    f2.Text = openFileDialog1.SafeFileName;
                    f2.Show();
                catch (IOException ioe)
                    MessageBox.Show("Error opening file:" + ioe.Message);
        private void exitToolStripMenuItem_Click(object sender, EventArgs e)
            Application.Exit();
        private void saveToolStripMenuItem_Click(object sender, EventArgs e)
            Form2 f2 = this.ActiveMdiChild as Form2;
            if (path == String.Empty)
                DialogResult saveResult = saveFileDialog1.ShowDialog();
                    path = saveFileDialog1.FileName;
                    try
                        StreamWriter sw = new StreamWriter(path);
                        sw.Write(f2.richTextBox1.Text);
                        sw.Close();
                        MessageBox.Show("Error saving file:" + ioe.Message);
            else
                    try
                        sw.Close();
        public void saveAsToolStripMenuItem_Click(object sender, EventArgs e)
            if (f2 != null)
                    try
                        sw.Close();
                    catch(IOException ioe)
        private void fontToolStripMenuItem_Click(object sender, EventArgs e)
            if (f2 != null)
                DialogResult saveResult = fontDialog1.ShowDialog();
                    try
                        f2.richTextBox1.Font = fontDialog1.Font;
                        MessageBox.Show("Error changing font" + ioe.Message);
        private void findToolStripMenuItem_Click(object sender, EventArgs e)
            Form3 find = new Form3();
            find.Show(this);
Form2
Code:
using System;
using System.Data;
using System.Linq;
using System.Text;
namespace proba_4
    public partial class Form2 : Form
        public Form2()
        public Form2(string text)
            richTextBox1.Text = text;
Form3
Code:
using System;
using System.Data;
using System.Linq;
using System.Text;
using Microsoft.VisualBasic;
namespace proba_4
    public partial class Form3 : Form
        public Form3()
        private void button1_Click(object sender, EventArgs e)
            int StartPosition;
            StartPosition = f2.richTextBox1.Text.IndexOf(this.richTextBox1.Text);
            string StartPosition1 = Convert.ToString(StartPosition);
            MessageBox.Show(StartPosition1);
            if (StartPosition == -1)
                MessageBox.Show("String: " + this.richTextBox1.Text.ToString() + " not found", "No Matches",
                MessageBoxButtons.OK, MessageBoxIcon.Asterisk);
                return;
            f2.richTextBox1.Select(StartPosition, f2.richTextBox1.Text.Length);
            f2.richTextBox1.ScrollToCaret();
            f2.Focus();
Falcon11 je offline   Reply With Quote
Staro 13.06.2014., 21:42   #2
Ahura
Datum registracije: Apr 2012
Postovi: 2
Pozdrav,
u formi3 na klik gumba stvaraš novu formu2, te onda od te nove forme pretražuješ rtb za tekst.
Pošto je tek stvorena ona za tekst u rtb nema ništa.
Ti bi trebao pretražiti formu2 stvorenu na formi1 putem klika, tako da bi
Formi3 bi trebo adati referencu na formu koju treba pretražiti pošto kasnije očito želiš radit nešto sa njom.
A čini mi se da bi možda htjeo predati listu svih formi2 stvorenih.
Javni ako nije jasno za detaljnije pojašnjenje.
Ahura je offline   Reply With Quote
