Staro 26.03.2014., 20:35   #1
Traitorous_8
Traitorous_8's Avatar
Lokacija: Vž
Postovi: 81
GA-M56S-S3 ploca i dual channel pitanje
Po prvi puta ikada odlucio sam se poigrati s memorijom i neke mi stvari nisu jasne oko dual channel-a.
Dakle imam GA-M56S-S3 plocu s 4GB RAM DDR2-800 (4 modula po 1GB) i upravo me zanima kako postici da radi u dual channel modu? 2 (prva) slota su zuta a druga 2 crvena.
Speccy mi pokazuje nesto sto me totalno zbunjuje:
Pod summary:
5,00GB Single-Channel DDR2 @ 376MHz (5-5-5-18)
Pod RAM:
Memory slots
Memory
Type DDR2
Size 5120 MBytes
Channels # Single
DRAM Frequency 376,7 MHz
CAS# Latency (CL) 5 clocks
RAS# to CAS# Delay (tRCD) 5 clocks
RAS# Precharge (tRP) 5 clocks
Cycle Time (tRAS) 18 clocks
Bank Cycle Time (tRC) 24 clocks
Command Rate (CR) 2T
Physical Memory
Memory Usage 37 %
Total Physical 3,00 GB
Available Physical 1,87 GB
Total Virtual 4,84 GB
Available Virtual 3,98 GB
Desni klik na my computer takodjer mi pise da imam 3GB RAM-a.
Koristim Win XP sa SP3 (necu dugo)
U cemu je kvaka?
Inace kod instalacije dodatnih modula primjetio sam da imam potencijalni hladni lem na ploci jer ako kvrcnem jedan modul tokom rada racunala, PC se smrzne. Da li je bas to uvijek uzrok hladni lem ili ne mora biti? To mi je najgora nocna mora kad god su u pitanju maticne ploce.
Ispricavam se ako je krivi podforum.
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore
Traitorous_8 je offline   Reply With Quote
Staro 26.03.2014., 20:39   #2
nino
nino's Avatar
Postovi: 12,597
Imas x32 windowse zato vidi do 3gb. instaliraj x64 sistem i sve ce biti upotrebljivo.
