Staro 03.02.2014., 19:19   #1
Traitorous_8
Traitorous_8's Avatar
Lokacija: Vž
Postovi: 81
Spybot 2.2 problem s blokiranim stranicama
Pozdrav,
Neki dan sam instalirao (nije mi to uopce ni trebalo) spybot 2.2 i nakon imunizacije ne mogu otvarati neke odredjene stranice (pogadjate koje?)
Dakle, cisto stvar principa i inata, kako to rijesiti da funkcionira kao prije instalacije tj. imunizacije? Probao sam undo opciju, probao sam system restore no nista nije pomoglo. Malo sam nesto prckao po host fileu no tamo imam samo ovo:
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
Koristim WIN XP sa SP3.
Sve ideje su dobro dosle!
Hvala
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore
Traitorous_8 je offline   Reply With Quote
Staro 07.02.2014., 19:14   #2
trnavausrcu
Datum registracije: Jan 2011
Postovi: 36
Koji firewall koristis i AV?
trnavausrcu je offline   Reply With Quote
