Povratak   PC Ekspert Forum > Računala > Software > Web dizajn, programiranje i ostalo
Staro 18.01.2014., 23:20   #1
dapapo
Lokacija: Kastav
Postovi: 7
SwiftMailer - Kontakt forma
<?php
session_start
include
"config.php";
$query  mysql_query("SELECT email FROM user WHERE id = '" $_SESSION['id'] . "'");
$emailres mysql_result($query0);
$user $_SESSION['username'];
if (
$_POST['submit'] != "") {
$username $user;
$predmet    $_POST["predmet"];
$poruka    $_POST["poruka"];
$email $emailres;
    if (
strlen($predmet) < OR strlen($predmet) > 20) {
header("Location: error.php?error=23");
        break;
    if (
strlen($poruka) < OR strlen($predmet) > 5000) {
header("Location: error.php?error=24");
        break;
include_once
"other/swift_required.php";
$subject $predmet;
$from = array($email => $user);
$to = array(
'xxxxx@gmail.com'  => 'xxxxx'
$text "Mandrill speaks plaintext";
$html "<em>Mandrill speaks <strong>HTML</strong></em>";
$transport Swift_SmtpTransport::newInstance('smtp.gmail.com'465'ssl');
$transport->setUsername('xxxxx@gmail.com');
$transport->setPassword('xxxxx');
$swift Swift_Mailer::newInstance($transport);
$message = new Swift_Message($predmet);
$message->setFrom($from);
$message->setBody($html'text/html');
$message->setTo($to);
$message->addPart($text'text/plain');
if (
$recipients $swift->send($message$failures))
 echo
'Message successfully sent!';
} else {
 echo
"There was an error:\n";
print_r($failures);
Pozdrav,
pokušao sam napraviti kontakt formu koja bi poruku poslala na Gmail. Koristio sam SwiftMailer, ali nekon što sam podesio kod uopće mi ne šalje poruku na mejl, tj. na mejl mi ne dolazi ništa. Jel zna tko u ćemu je problem i kako to riješiti? Otvoren sam i za druge opcije, ne mora biti SwiftMailer...
PHP kod:
<?php
session_start
include
"config.php";
if (
$username $user;
$email $emailres;
    if (
        break;
    if (
        break;
include_once
$subject $predmet;
$to = array(
if (
 echo
} else {
 echo
print_r($failures);
Zadnje izmijenjeno od: dapapo. 18.01.2014. u 23:36.
dapapo je offline   Reply With Quote
Staro 20.01.2014., 09:05   #2
zwer
crnjo
zwer's Avatar
Postovi: 1,907
Si probao obicnu php mail funkciju prvo testirat?
9900K-32GB-5TB-3060TI
zwer je offline   Reply With Quote
Staro 23.01.2014., 17:50   #3
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
Ako mene pitas od tih gotovih rijesenja sve upogonit s jquery valiadation...u protivnom te mogu obasipat spamom...druga stvar kao sto je zwer rekao najobicniji php i amen
esit: btw jesi podesio sve potrebno za odlazni mail...jel ti to lokalno ili na serveru
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline   Reply With Quote
