Staro 06.01.2014., 11:37   #1
sirupdzija
Datum registracije: Aug 2008
Lokacija: dasasdasda
Postovi: 161
3.5mm jack po pravak slušalica
može li se 3.5mm jack na slušalicama rastaviti ili potrgati ona plastika da se dođe do spojeva kako bih mogao zalemiti novi komad žice na njega ili puknuti stari dio?
ako ne može, zna li netko gdje kod nas ima za kupiti ovo:
http://www.ebay.com/itm/Gold-3-5mm-4...item485f3c2ccf
ili ovo
http://www.ebay.com/itm/10-PCS-3-5MM...item27d4590317
sirupdzija je offline   Reply With Quote
Staro 06.01.2014., 12:28   #2
konig_karl
lurkerus maximus
Lokacija: V.G.
Postovi: 91
Autor sirupdzija Pregled postova
ili ovo
naravno da ima. ako zivis u zg mozes otici u ElectronIC Center (Tratinska) ili u Chipoteku, cijena je 5 kn kom za plasticni, metalni je 1 kn vise.
kad sam si popravljao slusalice onda sam i sleevao donji dio zice paracordom
Sleeved Koss spark plug
CPU: AMD Athlon II x4 640
MBO: ASrock 870 Extreme3
RAM: 2x Corsair 2gb DDR3 (1333Mhz)
HDD: WD5000AAKS
VGA: Point of view GeForce GTX 460 768Mb
PSU: Corsair CX400W
Case: NZXT Source 210
Monitor: LG M2262D (22", 1920:1080)
OS: Windows 7 x64
Toshiba A200-23K
ekran: 15,4" WXGA
CPU: C2D T450 1.66 GHz
RAM: 1 Gb
HDD: Hitachi 160 Gb
VGA: HD2600 256MB
OS: Windows 7 x86
Samsung HD502IJ@IcyBox
Logitech Driving Force Pro
Logitech Wireless Desktop MK710
Sony NWZ-E443 + Koss SparkPlug
Creative WP 350
Nokia N97
Scott Sportster P3 2010
Frame: New Sportster Frame Alloy 6061
Fork: Sun tour NEX 4610 V2 HLO, Lockout susspensionfork 1 1/8, 63mm travel, Integrated 700C
Front Derailleur: Shimano Deore
Rear Derailleur: Shimano Deore RD-M592 / Shadow Type
Shifters: Shimano Deore SL-M590
Chain set: Shimano FC-M443-8-S
Chain rings: 48×36×26 Teeth
Bottom Bracket: Shimano BB-ES-25
Cassette: Shimano CS-HG50-9 11-32 Teeth
Chain: Shimano CN-HG53
Pedals: Wellgo C 128
Front Brake: Shimano BR-M486 F/R 160 mm Rotor
Rear Brake: Shimano BR-M486 F/R 160 mm Rotor
Brake Levers: Shimano BL-M 486 Disc
Handlebars: Scott Sportster OS
Stem: Scott Comp
Rims: Alex XC-44 Disc
Front Hub: Scott Comp Disc CL
Rear Hub: Shimano FH-RM65 CL
Spokes: stainless black, 14G / 2mm
Front Tyre: Schwalbe Smart Sam 700×35C
Rear Tyre: Schwalbe Smart Sam 700×35C
Seat post: Scott Sportster/Solution
Weight: 13.10kg
konig_karl je offline   Reply With Quote
Staro 06.01.2014., 13:41   #3
sirupdzija
Postovi: 161
a da li se može stari jack isto rastaviti i prelemiti? ili bas moram kupovati to, nisam iz zg a ne da mi se iskreno ni trazit po trgovinama tu kod mene ako mogu starog rastavit, a opet ne bih ga htio potrgat dok jos radi polovicno.
Staro 06.01.2014., 16:54   #4
konig_karl
lurkerus maximus
Lokacija: V.G.
Postovi: 91
ovisno o samom jacku, velika većina koji su mi prestali raditi su bili izvedeni u jednom komadu pa nisam ih mogao rastaviti
HDD: WD5000AAKS
PSU: Corsair CX400W
OS: Windows 7 x64
Toshiba A200-23K
ekran: 15,4" WXGA
RAM: 1 Gb
HDD: Hitachi 160 Gb
VGA: HD2600 256MB
OS: Windows 7 x86
Creative WP 350
Nokia N97
Stem: Scott Comp
Weight: 13.10kg
Staro 06.01.2014., 17:20   #5
Postovi: 23,603
Teško da ćeš origigi konektor rastaviti jer su u 99.9% slučajeva zaliveni.
Nisi stavio sliku svoga al kad ga se pogleda odmah je sve jasno.
Tako da vjerojatno trebaš ocvikat na mjestu gdje prekida ili par cm od konektora i zalemiti jedan od ovih:
http://www.chipoteka.hr/artikl/2675/utikac-35mm-stereo
http://www.chipoteka.hr/artikl/2676/...m-stereo-metal
Ako nisi vičan lemljenju možeš uzeti ovo:
http://www.chipoteka.hr/artikl/6471/...5m-goobay-bulk
pa onda malo cvikaš, "zamotaš" i izoliraš ...
Staro 13.01.2014., 21:50   #6
Night
Lokacija: Dbk
Postovi: 1,316
Ovaj metalni što je Nikky stavio je najbolji izbor. Ja sam ih kupio par komada u Elmatisa i promijenio na već nekoliko kabela (od slušalica, zvučnika, ...). Imam i plastične, ali to je obično dosta loše napravljeno i onda se događa da ne sjeda lijepo na metalni dio ili se izvlači kad ga povučeš.
Staro 13.01.2014., 22:20   #7
Frung
Frung's Avatar
Lokacija: zg westside
Postovi: 625
Možda je najlakše rješenje raskopati neke stare slušalice s ispravnim kabelom i jackom i prelemiti ih na sluške? Ili bi to bilo prebarbarsko rješenje jer se radi o nekoj kvaliteti?
Frung je offline   Reply With Quote
