Staro 19.12.2013., 02:48   #1
Traitorous_8
Traitorous_8's Avatar
Lokacija: Vž
Postovi: 81
Runtime error
Pozdrav,
Imam na jednoj particiji video fileove, windowsi su automatski prepoznali da se radi o video fileovima (use this folder type as a template) tamo je videos.
Dok god udjem u folder i saram po fileovima dobijem poruku o gresci:
Runtime error!
Program:C\WINDOWS\Explorer.exe
This application has requested the Runtime to terminate it in an unusual way.
Inace vezano je uz Visual C++.
Imam Win XP SP3.
Problem nestaje ako promijenim svojstva foldera iz videos u documents.
Sto da pokusam da rijesim taj problem? Za sada sam reinstalirao C++ ali nista.
Ono sto je zanimljivo je to da na toj particiji imam 2 foldera sa video fileovima. U drugom folderu je isto (use this folder type as a template) videos i nema problema. Jedina je razlika da je prvi folder u kojem je vecina HD fileova.
Hvala!
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore
Zadnje izmijenjeno od: Traitorous_8. 19.12.2013. u 02:54.
Traitorous_8 je offline   Reply With Quote
Staro 20.12.2013., 00:26   #2
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,139
lakse ti maknuti sve c++ runtimes pa onda na "prazno" probati nego reinstalirati
iako bi ja prije rekao da je vezano uz kodeke
pokreni process explorer pa vidi sta je hookano za explorer.exe kad ti se to desi
Why would you invite a mushroom to a Christmas party? He's a fun guy to be with.
Why do mummies like Christmas so much? Because of all the wrapping.
Why does Santa have three gardens? So he can "ho ho ho".
HumWeed je offline   Reply With Quote
