Postovi: 621
Procjena monitora
Ovako zanima me koliko bi mogao traziti para za ovaj monitor: ADI MicroScan M700 17" |
the luda ribetna
Postovi: 3,952
zgodan monitor...max 400 krznatih...,mozda cak 450 edit evo svima i specifikacije...i fakat su dobre ![]() Picture Tube 17" (16" diagonal viewable image) flat square tube (FST), high sensitivity, 0.27mm dot pitch, anti-reflection, glare coating Max. Resolution 1280 x 1024@ 60Hz Scanning Frequencies Horizontal : Vertical : 30 to 70 KHz 50 to 160 Hz Max. Video input Bandwidth 108 MHz Input Connector 15-pin D-sub Type Power Management EPA/Energy Star, NUTEK/TCO compliantVESA DPMS signaling method Front panel controls Power, Select, Adjust+, Adjust- EasyscreenTM Brightness, Contrast, H/V Size, H/V Position, Pincushion, Trapezoid, Parallelogram, Tilt, H/V Moire, Color, H/V Linearity, Top/Bottom Corner Management, Factory Reset, 3D (optional), Degauss. 3D Kit 3D Module (optional): 56.8K carrier, IR wireless transmitter;3D Glasses (optional): 56.8K carrier, IR wireless receiver. EMI Safety Regulations and FCC Class B/ DOC, VCCI Class2, CISPR 22, VCCI C-tick, CCIB, BCIQ, RFS43 Ergonomics ISO 9241-3 / 7/ 8, MPR II, TCO99 (optional) |
Postovi: 621
hvala ribo na ovako iscrpnom postu...ak znas nekog da mu treba monitor sam javi..i daj upali icq |
#4 | |
the luda ribetna
Postovi: 3,952
![]() ocu malo mira od vas sala sljedeci tj ak sve ide po planu sam ja opet 100% tu(konacno zavrsena selidba) |
