Staro 12.09.2005., 00:28   #1
BoBa ,:)
Lokacija: Mostar
Postovi: 7
Arrow Sta mislite o ovoj konfoguraciji?
Planiram uzeti ovu konfiguraciju pa me zanimaju vasi komentari...
MATICNA: BLKD945PSNLK Intel Desktop Board D945PSN - Supports Intel LGA 775 CPU including Pentium D / Intel 945P chipset / FSB 1066/800/533 MHz / 4DDR2 (Dual Channel) 667/533/400 / 4*SATA / PCI Express x16 / Intel High Definition Audio: Flexible 6-channel audio with jack sensing / LAN Gigabit solution / 2 PCI Express x1, 4 PCI / USB 2.0 x 8 / ATX FormFactor / Intel Express Instaler, Intel Desktop Control Center, Intel Audio Studio, Intel Desktop Utilities, Norton Internet Security, NTI CD-Maker, Musicmatch Jukebox, GameSpy Arcade, InterVideo Home Theater Silver, InterVideo WinDVD Creator Silver, Farstone RestoreIT! Lite, LANDesk System Manager, Intel Rapid BIOS Boot, Intel Precision Cooling Technology, Intel Digital Signature Technology, Intel Fault Tolerant Flashing, Intel Express BIOS Update, Multiple Language Support / 3 year limited warranty
PROCESOR : BX80547PG3400F Intel Pentium4 650 3.4GHz 2048K 800MHz LGA775 BOX
MEMORIJA : DDR2 512MB 240 pin, 533MHz, Kingmax ×2
GRAFICKA : CHAINTECH nVidia GeForce FX6600GT 128MB, PCI-E ,DDR, TV-out, DVI, 128bit DDR 3
HDD : Caviar 36.7 GB, WD360GD, SERIAL ATA, 8MB, 10000rpm RAPTOR
6Y200M0 Maxtor 200GB 7200 rpm 8MB SATA
BoBa ,:) je offline   Reply With Quote
Staro 12.09.2005., 00:40   #2
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,183
Mogao si reć zašto će služit konfa
Ako si zapeo za intela ok
Ovdjesu većinom ljubitelji amd-pa češ vidjet preporuke
Zašto uzimaš raptora,jest brz,al je i bučan,i grije se puno,rađe zemi maxtora 10 250 ili 300Gb 16mb,tu su ti negdje u brzini
ja ti predlažem ipak AMD
DFI Lan Party Ultra-D
AMD Athlon64 3000+Venice
AC Freezer64
Maxtor 10 300gb 16mb
6600Gt
2x512 Cosair value ili Geil value
Pioneer 110
Neko malo bolje napajanje tipa fortron ili chieftec ili tagan i enermaxa ako imaš love
Kućište po izboru
Staro 12.09.2005., 00:52   #3
E.T.
E.T.'s Avatar
Postovi: 2,458
Po 100-ti put koja je namjena konfiguracije? Nije ista stvar slazes li konfiguraciju na kojoj se mislis igrat ili samo za office,net, slusanje muzike koji film ili se bavis programiranjem ili obradom fotografija, videa, 3D modeliranjem, animacijom, raznim drugim CAD aplikacijama...
Cemu Raptor? Grije se i skup je a "obicnom" korisniku nis ne znaci...
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 12.09.2005., 04:43   #4
BoBa ,:)
Lokacija: Mostar
Postovi: 7
sluzit ce uglavnom za igranje, filmovi, muzika... nista profesionalno... i nije obavezno da je Intel
Staro 12.09.2005., 21:27   #5
E.T.
E.T.'s Avatar
Postovi: 2,458
Pa onda ovako:
Filmove i muzika neigraju neku ulogu dok su igre vec druga stvar...bilo bi dobro da si napisao barem pribliznu cijenu...
Vidim da si se odlucio za nesto skupljeg 64-bitnog Intela 650 (2200Kn) no ja bi se slozio s Gemmy-em i ustedio tu 1000Kn i uzeo AMD64 3000+ sa Freezerom64 i malo ga oc-ao te za razliku u cijeni uzeo jacu graficku karticu. Tu bi se dvoumio izmedu X800XL i 6800GT(2200-2700Kn makar bi se dalo na trznici ili newsima naci i puno jeftinije)... 2x512Mb DDR-a ovisno o financijama. HDD Seagate 160Gb... DVD i DVD-RW sa sto duzom garancijom (LG,NEC,Pioneer...)...Za napajanja se slazem s Gemmy-em... MBO nForce4 sck939 DFI ili Abit...
Staro 12.09.2005., 23:06   #6
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
matrox skoro = brz kao raptor:confused: na cem si ti pak pa nema te sanse da bude manja razlika od 40 mb...efektivno
blup
mc_fish je offline   Reply With Quote
Staro 13.09.2005., 00:11   #7
Darth Vader
Dark side Moderator
Darth Vader's Avatar
Postovi: 1,633
i sta ce ti intelova ploca, to je idijotarija.
Jak ko rakija!
Darth Vader je offline   Reply With Quote
