Staro 30.07.2013., 19:40   #1
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,244
Nvidia GeForce v326.41 Beta Driver
Release Summary
This driver enables GeForce to SHIELD streaming and is also a recommended driver update for the Windows 8.1 Preview. GeForce R326 drivers also provide performance increases for a variety of different games.
New in GeForce R326 Drivers
Performance Boost – Increases performance by up to 19% for GeForce 400/500/600/700 series GPUs in several PC games vs. GeForce 320.49 WHQL-certified drivers. Results will vary depending on your GPU and system configuration. Here is one example of measured gains:
GeForce GTX 770:
Up to 15% in Dirt: Showdown
Up to 6% in Tomb Raider
GeForce GTX 770 SLI:
Up to 19% in Dirt: Showdown
Up to 11% in F1 2012
SLI Technology
Added SLI profile for Spinter Cell: Blacklist
Added SLI profile for Batman: Arkham Origins
SHIELD
Enables GeForce to SHIELD streaming. Learn more here.
4K Displays
Adds support for additional tiled 4K displays
Extended support for tiled 4K features
Additional Details
Installs new PhysX System Software 9.13.0604.
Installs HD Audio v1.3.26.4
Includes support for applications built using CUDA 5.5 or earlier version of the CUDA Toolkit. More information at http://developer.nvidia.com/cuda-toolkit
Supports OpenGL 4.3 for GeForce 400-series and later GPUs.
Supports DisplayPort 1.2 for GeForce GTX 600 series GPUs.
Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP.
Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards.
http://www.geforce.co.uk/drivers/results/64663
Staro 31.07.2013., 08:24   #2
Mrakky
Mrakky's Avatar
Datum registracije: Oct 2012
Lokacija: Velika Gorica
Postovi: 115
mrakača, sa ovim driverima mi opče ni na trenutak ne zašteka TSW to sam igram pa jedino i za to znam kak se ponaša, naravno v sync na adaptive i kolko sam uspio primjetit u ovih pol sata igranja manje se zagrijava grafe i tiše su podosta od prethodnih beta drajvera, sam da još to ispeglaju više do finala, ugl. jako zadovoljan .
kad ulovim cca 2-3 čuke vremena budem ih onda istestirao dokraja pa budem znao mnogo više, al pretpostavljam da nebudu nešto značajno temperasture porasle.
ps. nisam mjerio ni u prethodnima temperature ni u ovima, al čujem ventovi se jako jako slabije čuju, pa pretpostavljam da se i manje grijem jer imam u afterburneru uključen profil temp-vent.
edit: jel ko probao na ovim drajverima oc-at, moje dve 660 non ti idu core clock +70 ,mem clock na +420 i power na 119%, možda bi i bi i više, idem probat igrat sad, na onim prijašnjim je išlo na +25 i +250 posle toga bi se drajveri kršili.
u vezi grijanja nakon duljeg igranja su tu negdije po buci, a i temp. je tu negdije, sad me zanima dal bude igranje ovaj oc izdržao.
edit2: ruše se, al dobro vrti sve i bez oc-a, tak da mi svejedno, sam sam htel videt jel to granica.
Zadnje izmijenjeno od: Mrakky. 14.08.2013. u 13:38.
Mrakky je offline   Reply With Quote
Staro 01.08.2013., 11:43   #3
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Evo ako imate SLI i igrate armu3 >
Windows 7/8 FIXED Issues
[SLI][Arma 3]: No performance improvement when SLI is enabled. [1248312]
viper je offline   Reply With Quote
Staro 10.08.2013., 18:52   #4
Mrakky
Mrakky's Avatar
Postovi: 115
ima kakvih info. o novim ne beta drajverima, datum izlaska?
Staro 10.08.2013., 19:18   #5
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,244
Autor Mrakky Pregled postova
Pa nije to igra da najavljuju datume izlaska
Staro 10.08.2013., 20:58   #6
Mrakky
Mrakky's Avatar
Postovi: 115
hehe, sve štima, sam znam da su prije ubrzo nakon bete izbacili regularne, al nema veze, čim dulje tim bolje očito da su ozbilno shvatili tolke kritike pa žele ispravit reputaciju svojih drajvera, ko zna možda če bit još koja beta.
makar ja sa ovom betom nemam nikakvih problema.
čisto informativno pitanje
Staro 18.08.2013., 10:48   #7
Mrakky
Mrakky's Avatar
Postovi: 115
počele se čudne stvari dešavat kod mene, tolko sam bio zadovoljan ovom betom i nvidia expirensom da mi se očito obilo o glavu, prije dva dana samo od sebe usred igranja počeli mi se rušit drajveri (beta) nikad prije sa ovim karticama to nisam imao, reko idem probat vratit na 320.49 nisu se rušili al je zapinjalo, fala bogu da radim back up sistema i vratio sam na 314.22 i na njima sve radi super čak i nešto malo bolje postavke mogu dobit u igrici, pa sam probao sa tih dravra update napravit na 320.49 ista stvar pomalo zapinje i neštološije postavke + još gro nekakvih erora u event viveru (čini mi se da onaj strem na sheld zafrkava i maknem kvačicu sa njega i dalje ista stvar i još neki winmint), a isto tako vidim na njihovom forumu da je ista stvar sa dosta ljudi jako rijetko neko kaže da je sve super, najviše se žale oni sa 7x0 serijom nekav tdr error i svakih čini mi se 36 sati moraju restart radit, na njihovom sajtu ima tool koji npravio jedan user, može koristit i za ati i za nvidiju i fakat makne sve drajvere čak i one generičke iz windoza, ali i nakon toga ista stvar(bar kod mene).
mislim da bum ostavil sad na ovim drajverima 314.22 i čekam da izađu novi, nadam se dabudu sve to ispeglali.
zbilja mi nije jasno kaj se počelo dešavat, je imo ko kad slična iskustva?
edit: e sada da se iskupe neka napišu tolko dobre drajvere da svaka serija ima boots bar 30-40%, nekak mi se čini da su okupirani onim shield-om, pa se zato to dešava sa drajverima, j... ih šilt
Zadnje izmijenjeno od: Mrakky. 18.08.2013. u 11:12.
Staro 18.08.2013., 11:22   #8
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,545
Nisi jedini sa TDR bugom, al ja svaki dan resetiram komp i nemam problema
Staro 18.08.2013., 11:33   #9
Mrakky
Mrakky's Avatar
Postovi: 115
Autor xulos Pregled postova
ma rađe sam ja vratio na stare drajvere, jer meni zna bit upaljen komp po tjedan i više, najviše mi čudno to kaj se to sam odjednom počelo dešavat, prije toga nikad nikaj, da je bar bil neki update ili nekaj, kužil bi, al ovak mi fakat nije jasno...
edit: kak stoje stvari na win 8, mislil sam sutra isprobat onaj 8.1, jel ti tam ista stvar?
edit2: navodno su izbacili novu betu 326.80 beta nađeno na nvidia forumu.
Nvidia has released GeForce 326.80 beta drivers.
http://www.nvidia.com/object/winxp-326.80-beta-driver.html
http://www.nvidia.com/object/winxp64-326.80-beta-driver.html
http://www.nvidia.com/object/win8-win7-winvista-32bit-326.80-beta-driver.html
http://www.nvidia.com/object/win8-win7-winvista-64bit-326.80-beta-driver.html
Notebook drivers
http://www.nvidia.com/object/notebook-win8-win7-326.80-beta-driver.html
http://www.nvidia.com/object/notebook-win8-win7-64bit-326.80-beta-driver.html
neznam ni sam dal da probam ili ne
ak to prba nek javi doživljaje, tnx
Zadnje izmijenjeno od: Mrakky. 20.08.2013. u 12:47.
