Staro 18.07.2013., 15:43   #1
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,438
Nvidia GeForce v326.19 Beta Driver
Release Summary
This is a recommended driver update for the Windows 8.1 Preview and includes performance increases for several games.
New in GeForce R326 Drivers
Performance Boost – Increases performance by up to 19% for GeForce 400/500/600/700 series GPUs in several PC games vs. GeForce 320.49 WHQL-certified drivers. Results will vary depending on your GPU and system configuration. Here is one example of measured gains:
GeForce GTX 770:
Up to 15% in Dirt: Showdown
Up to 6% in Tomb Raider
GeForce GTX 770 SLI:
Up to 19% in Dirt: Showdown
Up to 11% in F1 2012
SLI Technology
Added SLI profile for Spinter Cell: Blacklist
Added SLI profile for Batman: Arkham Origins
Additional Details
Installs PhysX System Software 9.13.0604.
Installs HD Audio v1.3.26.4
Includes support for applications built using CUDA 5.5 or earlier version of the CUDA Toolkit. More information at http://developer.nvidia.com/cuda-toolkit
Supports OpenGL 4.3 for GeForce 400-series and later GPUs.
Supports DisplayPort 1.2 for GeForce GTX 600 series GPUs.
Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP.
Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards.
http://www.geforce.co.uk/drivers/results/64510
Staro 19.07.2013., 14:49   #2
Mrakky
Mrakky's Avatar
Datum registracije: Oct 2012
Lokacija: Velika Gorica
Postovi: 115
je ko probap na win 7 64 bit, kolko čitam po njihovom forumu uje..li su stvar, podosta.
Mrakky je offline   Reply With Quote
Staro 19.07.2013., 14:50   #3
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,438
meni je sve ok
Staro 19.07.2013., 22:31   #4
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,570
Autor Mrakky Pregled postova
Ujebali su sve od pocetka 320.xx serije. Ja sam snimio ove pa cemo vidjeti, od 320.18 nemogu bit gori.
Staro 19.07.2013., 22:50   #5
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,438
Autor xulos Pregled postova
kako kome meni ni najmanji problem sa čitavom 320 serijom..subjektivno je
Staro 20.07.2013., 17:40   #6
Mrakky
Mrakky's Avatar
Postovi: 115
ja isto nikakvih problema nemam, ako i imam u kojoj igrici uključim adaptive v-sync i sve je kak treba bit, a i tiše su grafe onda, sve je ispeglano.
Staro 20.07.2013., 17:55   #7
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,438
meni je adaptive sync odmah prva stvar što uključim na global settings
Staro 27.07.2013., 16:23   #8
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,570
Maknite ovaj update ako ste ga instalirali http://answers.microsoft.com/en-us/w...2-16896a25dc3d
