Staro 03.09.2005., 12:57   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
VIA P4M800 Pro Chipset
Designed to support a full range of Intel Pentium 4 and Intel Celeron processors with an FSB of up to 800MHz, the VIA P4M800 Pro also supports a choice of DDR2-533/400 memory modules as well as DDR-400/333/266 SDRAM. The chipset´s multimedia features include the integrated S3 Graphics UniChrome Pro IGP core with outputs to CRT, LCD and standard definition TV, and support for 1080p HDTV with a compatible TV-Out or DVI encoder.
Combined with the VIA VT8237R South Bridge, the VIA P4M800 Pro offers native Serial ATA and V-RAID support (RAID 0, 1, 0+1), VIA Vinyl Audio, and Gigabit Ethernet with the VIA Velocity controller.
The VIA P4M800 Pro is currently shipping worldwide, so motherboards featuring the chipset are expected to be available soon.
Support for the latest Intel Pentium 4 Processors
Supports 800/533MHz FSB
Supports up to 16GB DDR2 or DDR Memory
V-Link 533MB/sec North/South Bridge interconnect
AGP 8X/4X
Integrated S3 Graphics UniChrome Pro
Optimized Unified Memory Architecture (UMA)
200MHz Graphics Engine Clock with separated 128-bit data paths
128-bit 2D and 3D Graphics Engine
Chromotion CE Video Display Engine
MPEG-2 Decoder
Video Deblocking
Adaptive De-Interlace
Full HDTV support up to 1080p
Two 8-bit Video Capture Ports
Three 12-bit Digital Video Ports for connection to TV out, Video Capture In, and external TMDS transmitter
Support for Microsoft DirectX 7.0, 8.0, 9.0 and Open GL support
Support for VIA Vinyl Audio
Serial ATA support for up to 4 devices
Integrated V-RAID with RAID 0, RAID 1, RAID 0+1, and JBOD (SATA) support
Parallel ATA133/100/66 support for up to 4 devices
Support for up to 8 USB 2.0/USB 1.1 ports
Support for VIA Velocity Gigabit Ethernet companion controller & Integrated 10/100 Fast Ethernet
Advanced System Power Management Support
http://www.digit-life.com/news.html?121666#121666
Staro 03.09.2005., 13:37   #2
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Za ne povjerovat, i dalje isti južni most
Staro 03.09.2005., 13:54   #3
Jelc
Super Moderators
Postovi: 17,485
Pa-ako bude povoljna cijena neće to biti tak loša platforma.
Vidjet ćemo kaj bu bilo od svega toga kad izađe na tržište.
