Staro 29.04.2013., 01:43   #1
Xenomorph
Arroyo settler
Xenomorph's Avatar
Lokacija: .::Zagreb::.
Postovi: 316
Ati Catalyst 13.4
http://support.amd.com/us/gpudownload/Pages/index.aspx
Resolved Issues
This section provides information on resolved known issues in this release of the AMD’s Catalyst™ Software Suite, AMD Catalyst™ 13.4
  • With the Radeon HD7790 graphics card, corruption may be seen in the game Tomb Raider with TressFX enabled
  • Texture flickering may be observed in DirectX 9.0c enabled applications
  • Corruption observed in Tomb Raider with TressFX enabled for AMD Crossfire and single GPU system configurations
  • Corruption observed on objects and textures in the game, Call of Duty – Black Ops 2
  • Corruption observed in the game, Alan Wake (DirectX 9 Mode) when attempting to change in-game settings with Stereoscopic 3D using Tridef
  • Corruption observed on textures in the game, Battle Field: Bad Company 2 with forced anti-aliasing enabled
  • Adobe Photoshop CS6 experiences screen flicker under Windows 8 based system
  • Horizontal line corruption may be observed with forced anti-aliasing enabled in the game, Dishonored
  • System hang may occur when scrolling through the game selection menu in the game, DiRT 3
  • F1 2012 may crash to desktop on systems supporting AMD PowerXpress (Enduro) Technology
Known IssuesThe section provides a summary of open issues that may be experienced with the AMD’s Catalyst™ Software Suite, AMD Catalyst™ 13.4
  • Jumping artifacts, and unsmooth playback of interlaced clips may be experienced using Cyberlink’s Metro UI players
  • A black screen may be observed when resuming from a S3/S4 sleep state if the display is unplugged during the sleep state on systems supported AMD PowerXpress (Enduro) Technology
Xenomorph je offline   Reply With Quote
Staro 15.05.2013., 10:14   #2
blackened
blackened's Avatar
Lokacija: Beli Manastir
Postovi: 1,281
Jel ima netko problema sa powerplay sa ovim driverima? Meni non stop radi na klokovima za 3d. Radi dobro nakon instalacije, no nakon idućeg reseta ili gašenja računala klokovi su na max stalno.
Staro 15.05.2013., 14:17   #3
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,176
Ja sam imao jedan put problem da mi nije vratio na 3D clockove nakon više ALT-TAB... ali inače nikakvih problema.
Staro 15.05.2013., 15:11   #4
drle1
drle1's Avatar
Lokacija: Velika Gorica
Postovi: 182
meni pokazuje samo cpu settingse, ne zeli mi instalirat/pokazat i gpu settings
da li netko zna kako rijesiti taj problem?
Zadnje izmijenjeno od: drle1. 17.05.2013. u 14:57.
drle1 je offline   Reply With Quote
Staro 04.06.2013., 20:48   #5
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Zna neko zašto se driver od 29.05 i dalje zove 13.4?
Staro 07.08.2013., 16:20   #6
jur
jur's Avatar
Postovi: 45
e to se i ja pitam, ni meni to nije jasno
jur je offline   Reply With Quote
