Staro 24.04.2013., 01:51   #1
alengrosevic
alengrosevic's Avatar
Postovi: 3,793
AMD Catalyst 13.4 WHQL
Staro 24.04.2013., 13:56   #2
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,179
Jel imam ikakvih release notes-a? Čisto me zanima prije nego ih krenem instalirati ovih dana
Staro 24.04.2013., 17:55   #3
Brain32
Brain32's Avatar
Postovi: 498
Nakon što me je jedna od beta pošteno razj**** iskreno se ne usudim ovo instalirat
Brain32 je offline   Reply With Quote
Staro 25.04.2013., 04:14   #4
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Autor JC Denton Pregled postova
Feature Highlights of AMD Catalyst™ 13.4
Support added for AMD Radeon HD7790 and AMD Radeon HD 7990
Catalyst Driver optimizations to improve performance in Far Cry 3, Crysis 3, and 3DMark
Significantly improves latency performance in Skyrim, Boderlands 2, Guild Wars 2, Tomb Raider and Hitman Absolution
Performance gains seen with the entire AMD Radeon HD 7000 Series for the following:
Batman Arkham City (1920x1200): Performance improvements up to 5%
Borderlands 2 (2560x1600): Performance improvements up to 10%
Quake Wars (1920x1200): Performance improvements up to 13%
Hitman Absolution (2560x1600): Performance improvements up to 11%
Wolfenstein MP (1920x1080): Performance improvements up to 11%
Civilization V (2560x1600): Performance improvements up to 5%
Delivers support for the following OpenGL 4.3 features:
GL_ARB_compute_shader
GL_ARB_multi_draw_indirect
GL_ARB_shader_storage_buffer_object
GL_ARB_arrays_of_arrays
GL_ARB_clear_buffer_object
GL_ARB_ES3_compatibility
GL_ARB_explicit_uniform_location
GL_ARB_fragment_layer_viewport
GL_ARB_invalidate_subdata
GL_ARB_program_interface_query
GL_ARB_shader_image_size
GL_ARB_stencil_texturing
GL_ARB_texture_buffer_range
GL_ARB_texture_query_levels
GL_ARB_texture_storage_multisample
Meni odlicni driveri.FPS skroz poludio u BF3, me happy!
Alph4Dawg je offline   Reply With Quote
Staro 25.04.2013., 09:57   #5
alengrosevic
Postovi: 3,793
Staro 25.04.2013., 19:49   #6
Romano.Cule
Outer Space
Romano.Cule's Avatar
Lokacija: Vinkovci
Postovi: 836
Ajmo biti realni i reci da je 5% statisticka greska. Kad imas 60 fps-a u nekoj rezoluciji i dobijes 3 i onda to proglasavati napretkom onda je to po meni cista glupost. Vise je bitnija stabilnost i da smanje micro stutering
Staro 25.04.2013., 21:30   #7
JC Denton
JC Denton's Avatar
Postovi: 3,179
Autor Romano.Cule Pregled postova
5% nije statisticka greska ako je rezultat ponovljiv. Znaci ako sam mjerio 20 puta sa novim driverima i 20 puta sa starim, i prosjek kod novih je 5% veci, nije to nikakva statisticka greska. Statisticka greska se ne definira tako.
S druge strane, slazem se da je nebitno imas li 60 ili 63FPS, ako imas druge probleme kao izrazito neujednacen frametime i slicne gluposti koje je AMD poceo rijesavati sa 12.11 Beta driverima.
A stabilnost je vec manje vise standardna, odavno se ne sjecam da mi se komp srusio zbog greske u grafickim driverima... naravno da uvijek mogu ukakit stvar, ali nadajmo se da nece
Staro 25.04.2013., 21:36   #8
Baja 001
Baja 001's Avatar
Postovi: 7,504
Meni naizgled isto, doduše igran samo F1 2012... (HD7850)
Staro 25.04.2013., 22:03   #9
Romano.Cule
Outer Space
Lokacija: Vinkovci
Postovi: 836
Da,dobro,bitnije je da povecaju minimalni FPS da se ne osjeti taj pad prilikom vece kolicine akcije na ekranu.Ali znalo mi se dogadjati sa starijim verzijama greska "Display driver stopped responding and has recovered",ali sa 13.1 i novijima ne dogadja se vise.Barem meni.
Staro 26.04.2013., 13:22   #10
Momir
Momir's Avatar
Postovi: 1,012
Nego, kako je ova tema zavrsila pod AMD, a ne ATi?
Momir je offline   Reply With Quote
Staro 26.04.2013., 14:18   #11
Romano.Cule
Outer Space
Lokacija: Vinkovci
Postovi: 836
Pa ja koliko znam,ATI vise ne postoji,i da se radi o AMD Radeon grafickama i AMD driverima 13.4,pa ne kuzim zasto se cudis ?!
Staro 26.04.2013., 15:37   #12
windfucker
Čudi se sa pravom, imamo ATI podforum, i dok je tako ova tema tamo i spada, poradi lakše preglednosti Foruma.
Uostalom, mod će već to prebaciti kada uhvati vremana, siguran sam
