Datum registracije: Aug 2008
Postovi: 2,000
Tast i mis prestanu radit
Daklem, G510 tast i G600 mis, zadnji Logitech software na djelu. Dogodilo se 2 puta, jednom preko noci, jer comp ne gasim, samo monitor, ujutro mis ili tast ne trzaju. Drugi put prije par min za vrijeme gledanja filma. Jednostavno mis nema kursora, ne trza na nista, ista stvar sa tastaturom, al komedija je da mi ctrl-alt-del radi, tamo biram task manager normalno, al nema koristi jer nema kursora i opet se nemoze nista napravit. Probao druge portove, nista. Film se i dalje vrtio bez greske ![]() Na kraju je ostao samo reset. Event manager za to vrijeme kaze sljedece: Driver Management has concluded the process to add Service usbccgp for Device Instance ID USB\VID_046D&PID_C22D\5&1CAA961E&0&2 with the following status: 0. Driver Management concluded the process to install driver FileRepository\usb.inf_amd64_neutral_e2b28ecac19a29af\usb.inf for Device Instance ID USB\VID_046D&PID_C22D\5&1CAA961E&0&2 with the following status: 0x0. Driver Management has concluded the process to add Service HidUsb for Device Instance ID USB\VID_046D&PID_C22D&MI_00\6&2DC63C51&0&0000 with the following status: 0. Driver Management concluded the process to install driver FileRepository\input.inf_amd64_neutral_42ef7994fe41f587\input.inf for Device Instance ID USB\VID_046D&PID_C22D&MI_00\6&2DC63C51&0&0000 with the following status: 0x0. Driver Management has concluded the process to add Service HidUsb for Device Instance ID USB\VID_046D&PID_C22D&MI_01\6&2DC63C51&0&0001 with the following status: 0. Driver Management has concluded the process to add Service kbdhid for Device Instance ID HID\VID_046D&PID_C22D&MI_00\7&2F4EF054&0&0000 with the following status: 0. Driver Management has concluded the process to add Service kbdclass for Device Instance ID HID\VID_046D&PID_C22D&MI_00\7&2F4EF054&0&0000 with the following status: 0. Driver Management concluded the process to install driver FileRepository\keyboard.inf_amd64_neutral_423c286802951189\keyboard.inf for Device Instance ID HID\VID_046D&PID_C22D&MI_00\7&2F4EF054&0&0000 with the following status: 0x0. Neke od ovih entrya pretpostavljam da javljaju da je prikljucen device i da je win za njih stavio drivere. Al zasto je krepalo sve samo od sebe. Nigdje nije postavljeno da usb device budu iskljuceni radi stednje struje. Ideje? |
Datum registracije: Oct 2010
Postovi: 289
Jesi probao na nekom drugom kompu?Neki drugi OS?Koji OS koristiš? To si novo stavio pa ne radi,ili već duže vrijeme koristiš to pa se tek sad počeli pojavljivat problemi? |
Postovi: 2,000
Os je Win7 X64, novih drivera nema za maticnu. Kad sam dodao G600 sve je radilo mjesecima bez greske. Prije 2 mjeseca dodao G510 i eto se 2 puta dogodi ovo sranje. Mozda je Logitech Gaming Software, jer nista ne radi kao da je usb mrtav, al sve svijetli i ctrl+alt+del kombinacija radi. Tako da znam da nije sve mrtvo. Na c+a+d screenu mis i tast rade bez problema. Znaci nije zaglavljena tipka, i nije freezao OS. Sumnjam na USB preko softwarea o Logitecha, prije nije bilo problema. Odavno je izgaseno da OS gasi USB, a posto se jednom dogodlilo usred rada, to izbacuje sleep teoriju radi stednje struje. |
Postovi: 2,000
Gle u 2 mjeseca se samo 2 puta dogodilo, jednom nakon par sati neaktivnosti, a jednom u sred geldanja filma. Nemogu reproducirat problem jer je izgleda random i rijetkost. A pitao sam na logi forumu, official odgovor je reinstal softwarea, sta je pointless jer je zadnji soft itako instaliran. Neka je caka u tome da c+a+d radi kao override kad nista drugo nece, pa mislim da ako sav input ide kroz njihov soft da je do njega. Poprilicno glup problem. |
#9 | |
Postovi: 289
