Staro 25.08.2005., 00:48   #1
Mailman
Mailman's Avatar
Postovi: 1,606
Talking Jetway 939GT4-SLI - "revolucionarni" dizajn
http://www.anandtech.com/mb/showdoc.aspx?i=2506
Pa kako se toga prije nisu sjetili?
A i performanse su usporedive s DFI-jem...
Mailman je offline   Reply With Quote
Staro 25.08.2005., 00:52   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Hm, rađe da su ubacili još jedan x1 PCIe utor.
MSI je to najbolje rješio, putem BIOS-a (Digital SLI Switch) bez ikakvih jumpera/dumpera i sličnih sranja...
Staro 25.08.2005., 08:39   #3
Mailman
Mailman's Avatar
Postovi: 1,606
A gdje bi onda stavio samo jednu grafičku?
Kažu da to "limitira" overclocking....
Other manufacturers like Asus have recently brought out SLI boards that use more expensive auto-switching technology where SLI can be turned on or off in BIOS. The advantage is mechanical simplicity, but the disadvantage is that overclocking performance may be compromised with a smaller range of overclocking than the more commonly used paddles and jumpers.
Jetway does not need a paddle card, or jumpers, or switches in this arrangement. The design is simplicity in itself. What's more, this board theoretically could be a better performer without the paddle, jumpers or switches that can limit overclocking performance.
This brings us back to the earlier question of whether or not the dedicated slots with no paddles, jumpers, or switches might improve performance. It is clear that the Jetway performs very well in overclocking, and if this design is the reason, then others should copy the Jetway design.
Staro 25.08.2005., 08:51   #4
atha
atha's Avatar
Postovi: 9,067
da je samo meni ovo tako blesavo ili? :confused:
___________
Just atha
x
Staro 25.08.2005., 12:48   #5
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Ma, meni je ta cijela priča mutava (mislim na SLI).
Staro 25.08.2005., 16:07   #6
Mljac
Mljac's Avatar
Datum registracije: Feb 2003
Lokacija: Zaprešić/Laduč
Postovi: 461
Imaš pravo, stvarno je SLI mutava špreha, pogotovo sada kad se sve više procesori pokazuju kao kočnica.
A vjerujem da bi i ATI već imao daleko bolje kartice i što je interesantnije bile bi već na tržištu da dobar dio korisnog vremena nemoraju utrošiti na pandan SLI-u.
Mljac je offline   Reply With Quote
