Datum registracije: Dec 2011
Postovi: 5
Instalacija programa kada se user logira
Dragi svi, molim vas za pomoć, imam popis računala na kojima trebam izbrisat Office 2002 Standard te instalirat Office 2003 Pro. Napravio sam MST paket za Office 2003 Pro te sam u chained instalaciju dodao i instalaciju compatibility packa 2007. Instalacija testirana i radi. Neznam jeste li upoznati ali za deploy koristim PDQ Deploy. Napravio sam 3 step-a. 1. step brise stari compatibility pack 2. step brise office xp std te 3. step instalira office 2003 pro. Evo primjer skripte: <?xml version="1.0" encoding="utf-8"?> <AdminArsenal.Export Code="PDQDeploy" Name="PDQ Deploy" Version="2.1.1.0" MinimumVersion="2.1.0.4"> <Installer Name="Uninstall Office STD v10.0.6626.0 and install Office 2003 PRO" Description="" CopyMode="Push"> <Step Type="Command" IgnoreError="true" Title="unistall compatibility pack"> <Conditions> <Condition TypeName="OperatingSystem"> <Details> <Architecture>Bits32</Architecture> <Version>All</Version> </Details> </Condition> </Conditions> <Command Command="Msiexec /x {90120409-6000-11D3-8CFE-0050048383C9} /qn /norestart" SuccessCodes="0"> <Files></Files> </Command> </Step> <Step Type="Command" IgnoreError="true" Title="unistall office xp std"> <Conditions> <Condition TypeName="OperatingSystem"> <Details> <Architecture>Bits32</Architecture> <Version>All</Version> </Details> </Condition> </Conditions> <Command Command="Msiexec /x {90120000-0020-0409-0000-0000000FF1CE} /qn /norestart" SuccessCodes="0"> <Files></Files> </Command> </Step> <Step Type="Install" IgnoreError="false" Title="Install Office 2003 PRO"> <Conditions> <Condition TypeName="OperatingSystem"> <Details> <Architecture>Bits32</Architecture> <Version>All</Version> </Details> </Condition> </Conditions> <Install FileName="\\HRDS4MBAH9\deploy\office2003pro\SETUPPRO.EXE" IncludeDirectory="true" MsiOperation="Install" MsiRestart="Never" MsiQuiet="true" Parameters="/settings "\\hrds4mbah9\deploy\office2003pro\FILES\SETUP\SETUP.ini"" SuccessCodes="0,1641,3010" CustomCommandLine=""> <Files></Files> </Install> </Step> </Installer> </AdminArsenal.Export> Sad bi htio napraviti login skriptu da sve to odradi kada se user non-admin logira. Pokušao sam sa batch skriptama koje rade ali samo ako je user admin. Hvala vam na pomoći |
