Staro 27.11.2012., 14:13   #1
Postovi: 8,243
KGB - Kepler BIOS Editor/Unlocker
Za sve vas entuzijaste i vlasnike 6xx kartica
Autor CrazyNutz Pregled postova
KGB (Kepler Golden BIOS) Is an Nvidia Kepler BIOS Editor/Unlocker program I have written. Enjoy
KGB supports: GTX680, GTX670, GTX660Ti, and GTX660 for now.
Usage Example 1: kgb.exe your_bios.rom
This will display info from the bios.
Usage Example 2: kgb.exe your_bios.rom unlock
This will unlock your BIOS. Make sure you have a backup of your original BIOS file!!!!!!!!!!!!!!!!!!!
Right now that is it. It will unlock to 150% Power, Voltage 1.1875v (1.2125v On Boost), and Fan Range to 30% - 100% (Future versions will allow you to define these values)
Don't ask me to tweak the values (i.e. voltage, power etc.) because this version is just Alpha, and I will be adding the ability to change the values yourself.
WARNING: KGB works on all the bios files I have so far. However that's not to say it will work on yours. Make sure to look at the output of KGB after you unlock,
If something looks fishy do not flash it. If something goes wrong I take no responsibility. Use at your own risk!!!
Download:
https://www.dropbox.com/s/3wiuizftusj2rcy/kgb_a0.4.zip
Version a0.4
Added support for 660 OEM
Added extra error checking
izvor: extremesystems
Staro 27.11.2012., 15:49   #2
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,540
drug brko ti prvi pa cu ja
Staro 27.11.2012., 17:15   #3
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Ja nebi. Nije to bas Nvidia bios editor pa da vidis kaj si napravio, nego pitaj boga kaj ce napravit od fan profila, klokova i ostaloga. Dok se to ne ispegla nije vrijedno skidanja..
Staro 03.12.2012., 23:29   #4
hahahaha... malo morgen još imamo ove prvoborce iz MSI-ja koji imaju kakti overvoltane điđe za 100% na sebi i još da idemo soka davati... a ne ne ako dobijem na Bingu, onda može
Staro 03.12.2012., 23:38   #5
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,540
ništa, čekamo onda 770ti za poboljšanja
Staro 03.12.2012., 23:47   #6
ne mećem ja nikakve mutne neisprobane pizdarije na grafe 2000+ kn. igrao sam se sa nibitorom ili kako se već zove, kad sam furio GTX 260... ali sada, no way toliko se muda ipak nema
