Staro 03.08.2012., 15:24   #1
M.U.P.
M.U.P.'s Avatar
Lokacija: Rijeka - malo iznad :)
Postovi: 372
win xp recovery console - gdje je taj vrag? plsss help!!
komp se nece bootat iz razloga sto je registry coruptan..
missing or corrupt file : winxp\system32\config\system
surfajuci sam nasao da se moze rjesit preko cmda iz recovery console..
At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line:
md tmp
copy c:\windows\system32\config\system c:\windows\tmp\system.bak
copy c:\windows\system32\config\software c:\windows\tmp\software.bak
copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
copy c:\windows\system32\config\security c:\windows\tmp\security.bak
copy c:\windows\system32\config\default c:\windows\tmp\default.bak
delete c:\windows\system32\config\system
delete c:\windows\system32\config\software
delete c:\windows\system32\config\sam
delete c:\windows\system32\config\security
delete c:\windows\system32\config\default
copy c:\windows\repair\system c:\windows\system32\config\system
copy c:\windows\repair\software c:\windows\system32\config\software
copy c:\windows\repair\sam c:\windows\system32\config\sam
copy c:\windows\repair\security c:\windows\system32\config\security
copy c:\windows\repair\default c:\windows\system32\config\default
eh sad.. ubacim ja xp cd, dignem, al nemam opciju za repair..
imam 2 particije koje su na kompu i na dnu gdje bi trebao bit R for repair, ja ga nemam, vec imam samo ENTER=install D=delete partition F3= quit..
ako lupim enter na particiju na kojoj su trenutno winsi -
CAUTION: A \WINXP folder already exist that may contain a windows instalation..
ako nastavim postojeca instalacija ce bit prebrisana..
All files, subfolders, user accounts, applications, security and desktop settings for that windows instalation will be deleted..
my documents may also be deleted..
i mogu stisnuti L za - to use the folder and delete the existing windows instalation in it..
dal nemam recovery console jer cd nije orig pa mozda nema na njemu?
ima li koji drugi nacin?
ako stisnem L i pregazim instalaciju, dal ostalo ostaje (program files...)
hvala za pomoc!
M.U.P. je offline   Reply With Quote
Staro 03.08.2012., 15:26   #2
nino
nino's Avatar
Postovi: 12,613
Bootaj neki hirens sa minixp-om pa napravi to sto se trazi. Repair opcije nema jer instalacijski ne prepoznaje modane win.
Staro 03.08.2012., 16:01   #3
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
da, ovo je problem - A \WINXP to nije standardna windows putanja i direktorij, što znači modani win, što znači - banana od službene podrške M$ za recovery i ostale điđe.
Staro 03.08.2012., 16:08   #4
M.U.P.
M.U.P.'s Avatar
Postovi: 372
ok, znaci tako..
Hirens' Boot DVD 15 0 Restored Edition V 1 0
1.7 gb ima.. svasta su utrpali unutra..
Mini Windows XP environment included in the CD. (4th option of
the main boot menu).
dakle to je to?
btw, zbog cega dolazi do ovakivih situacija?
hard disk u pitanju? bs?
Staro 03.08.2012., 17:32   #5
nino
nino's Avatar
Postovi: 12,613
Win.
Staro 03.08.2012., 21:21   #6
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
mini xp ti diže live XP distru, preko nje imaš pristup svojim diskovima.
Staro 04.08.2012., 13:13   #7
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,136
recovery i repair nije isto
recovery ti se nudi pri samom bootanju sa cd-a
imas par sekundi gdje ti pise neka sranja i onda ti veli "for recovery bla bla bla press" i onda neka tipka
dok kao vec napisano repair ti se kasnije nudi sa tipkom R
HumWeed je offline   Reply With Quote
Staro 04.08.2012., 15:56   #8
domy_os
domy_os's Avatar
Postovi: 18,851
Ako budeš ovo radio, cijeli registry će ti se obrisati, tj. vratiti u stanje nakon nove instalacije Windowsa. Vrati samo file C:\WINDOWS\system32\config\system pa onda vidi kako će izgledati.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 04.08.2012., 16:00   #9
M.U.P.
M.U.P.'s Avatar
Postovi: 372
ok, dignuo sam sa hirensima mini xp, but..
za replaceat tih par fajlova 2 su nacina.. preko cmda, putem ovih gore naredbi, medjutim javi mi : The system cannot find the file specified.
mogu se izvuc i iz restore foldera tih par config fajlova, al naravno da racunalu nema ni jednog pointa, restore je diseblean..
dakle, koja mi opcija preostaje?
sad se checkira hard za errore, al od tog nema kruha..
dal mogu ja ubacit od negdje drugdje? sa nekog drugog kompa?
pretpostavljam da ne, posto je to registry, al nije me sram pitat
dajte pls savjet, osim friske instalacije..
domy - tako sam tocno i mislio napravit, samo eto, neznam od kud i kako da uzmem taj file..
Staro 04.08.2012., 16:11   #10
domy_os
domy_os's Avatar
Postovi: 18,851
Možeš ih prebaciti jedino s PC-a koji je klon ovome, u svim ostalim primjerima nemoj (nije da ne možeš). Ako imaš neki backup, izvuci iz njega, a ako nemaš, to je onda problem. Ili kopiraj s normalnog instalacijskog CD-a ili reinstaliraj Windowse.
Staro 04.08.2012., 16:32   #11
M.U.P.
M.U.P.'s Avatar
Postovi: 372
ok, nasao sam na ovo :
REN C:\WINDOWS\SYSTEM32\CONFIG\SYSTEM SYSTEM.OLD
COPY C:\WINDOWS\REPAIR\SYSTEM C:\WINDOWS\SYSTEM32\CONFIG
ova prva naredba je dala error (system cannot find..)
al nakon druge je pisalo 1 files copied sto mi dalo malo nade.. exit, restart i boot to desktop
ma nema sladjeg kad se vec pripremas za predaju, i nadjes u zadnji tren nacin hh..
hvala svima na helpu - najjaci ste !
Zadnje izmijenjeno od: M.U.P.. 04.08.2012. u 16:57.
