Staro 24.05.2012., 13:33   #1
KillerLoop2807
motion graphics freak
KillerLoop2807's Avatar
Datum registracije: Jun 2010
Lokacija: Kutina
Postovi: 177
Upload problem - puca veza
Pozdrav!
Imam veliki problem sa uploadom.
Imam 4mbit ADSL i Max TV. Sve super šljaka dok ne pustim slati Jumbo
mail od cca 150Mb.
Tada u 90% slučajeva na sekundu se odspoji veza i prekine mi slanje. Isto je
i kod uploada na neki server ili YT.
Kada mi je SZK resetirao liniju, taj dan je bilo OK, sada opet isto.
Kako to riješiti?
Code:
    Link Information
Uptime:    0 days, 0:02:11
DSL Type:    G.992.5 annex B
Bandwidth (Up/Down) [kbps/kbps]:    828 / 8.703
Data Transferred (Sent/Received) [MB/MB]:    4,91 / 54,99
Output Power (Up/Down) [dBm]:    13,5 / 18,5
Line Attenuation (Up/Down) [dB]:    9,0 / 13,0
SN Margin (Up/Down) [dB]:    25,5 / 19,0
Vendor ID (Local/Remote):    TMMB / BDCM
Loss of Framing (Local/Remote):    81 / 0
Loss of Signal (Local/Remote):    9 / 0
Loss of Power (Local/Remote):    0 / 0
Loss of Link (Remote):    0
Error Seconds (Local/Remote):    9 / 0
FEC Errors (Up/Down):    0 / 63
CRC Errors (Up/Down):    0 / 0
HEC Errors (Up/Down):    363 / 0
Zadnje izmijenjeno od: KillerLoop2807. 24.05.2012. u 13:39.
KillerLoop2807 je offline   Reply With Quote
Staro 28.05.2012., 13:42   #2
azure
Datum registracije: Mar 2009
Postovi: 157
Ummmm pogledaj koliki ti je MTU u modemu ako je 1500 pokušaj staviti 1420 ili 1460 pokušaj tako
azure je offline   Reply With Quote
