Staro 15.05.2012., 14:14   #1
LorlonWarrior
Datum registracije: Feb 2010
Lokacija: Vukovar
Postovi: 69
Exclamation Microsoft .NET Framework error
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
The SMTP server requires a secure connection or the client was not authenticated. The server response was: 5.7.0 Must issue a STARTTLS command first. x23sm3189480bkw.12
DETAILS:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Net.Mail.SmtpException: The SMTP server requires a secure connection or the client was not authenticated. The server response was: 5.7.0 Must issue a STARTTLS command first. x23sm3189480bkw.12
at System.Net.Mail.MailCommand.CheckResponse(SmtpStatusCode statusCode, String response)
at System.Net.Mail.SmtpTransport.SendMail(MailAddress sender, MailAddressCollection recipients, String deliveryNotify, SmtpFailedRecipientException& exception)
at System.Net.Mail.SmtpClient.Send(MailMessage message)
at yooowningthisshit.Form1.stealers_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
Stub
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/XxX/AppData/Roaming/Microsoft/Windows/Start%20Menu/Programs/Startup/winlogin.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Management
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
_________________________________________________________________
Ako izađem iz errora na X, vrati se nakon minute. Ako kliknem Continue, vrati se nakon minute. Ako kliknem Quit, otvori mi se Anchorfree Download Helper 1.57 Setup i baš ko da želi da ga instaliram. Izađem iz njega, kliknem opet Quit na error, opet mi uđe u setup. Vjerojatno sam pokupio nekako neki spam koji baš želi da instaliram taj Anhorfree štagod da je to i neće odustat dok ga ne instaliram (možda čak i kad ga instaram nebi odusto).
Znači pomozite ako boga znate molim vas, trebam se rješiti tog errora i tog setupa koji mi konstantno pop uppa od nikuda
Zadnje izmijenjeno od: LorlonWarrior. 15.05.2012. u 14:21.
LorlonWarrior je offline   Reply With Quote
Staro 15.05.2012., 14:17   #2
nino
nino's Avatar
Postovi: 12,600
Imas xx topica vezano za rjesavanje gamadi. AV, Malwarebytes, Combofix, HiJack...itd.
Ubit u msconfigu sve sto je nevazno za dizanje sistema i to je to.
Staro 15.05.2012., 16:22   #3
LorlonWarrior
Lokacija: Vukovar
Postovi: 69
A i mislio sam da je gamad u pitanju, samo sam tražio potvrdu više manje. Budem probo iskemijat neš onda s nekim od softvera.
