Staro 18.07.2005., 16:12   #1
Aron Doberman
Aron Doberman's Avatar
Lokacija: Crikvenica
Postovi: 33
Vaše mišljenje o cooler thermaltake beetle?
Upravo saam vidio na Linksu (www.links.hr) da su dobili novi cpu cooler pa me zanima vaše mišljenje o njemu.Da vam malo pomognem daču vam i malo specifikacija:
Application for Intel P4 478/775, and AMD K7, K8
Beetle-style, streamlined design
Blue LED (inside) and flash LED (front) bring bright and dazzling effect
Aluminum fin soldered to copper base, perfect contact to ensure the best performance
Heatpipe technology dissipates heat effectively
Manual control fan, can be installed in both 3.5 drive bay and PCI slot
P/N
CL-P0086
Compatibility
Intel P4 LGA775
Intel P4 478 Prescott FMB1.5
AMD Athlon 64 / Athlon 64 FX
AMD Athlon XP up to 3400+
AMD Sempron up to 3400+
Heatsink Dimension
80 x 75 x 127 mm
Heatsink Material
Copper Base & Aluminum Fin (39Fin)
Heatpipe
Copper Tube ( 6 mm) x 3pcs
Fan Dimension
90 x 25 mm
Fan Speed
1600rpmč4300rpm
Noise Level
20dBč44.5dB
Color
UV red, black and silver
Flash LED Multi-color
Weight
581 g (20.51 oz)
Moje mišljene je da izgleda lijepo ali mozda malo preglomazno i tesko,a i treba ti poprilično veliko kučište ja imam Thermalrock Dragon kučište i nisam siguran da bi stalo unutra,a poprilično je veliko 490 x 205 x 585 mm.Zanima me i vaše mišljenje i dali ga je tko koristio?
Aron Doberman je offline   Reply With Quote
Staro 19.07.2005., 02:56   #2
srkyno1
srkyno1's Avatar
Lokacija: st
Postovi: 1,084
neisplativo pošto je big typhoon za 30 više, tiši i bolje hladi.
ASUS K8N & Zalman NB32K @ HTT x3 / A64 3000+ 263x8 / 2x256MB TwinMOS @ 210 / Club3D 5200 & Zalman ZM80C-HP / Maxtor 30GB, 2MB / WD Caviar 80GB, 8MB / Maxtor DM10 250GB, 16MB / Xilence 420W / CoolerMaster Centurion 5
srkyno1 je offline   Reply With Quote
Staro 19.07.2005., 08:56   #3
nikola-m
nikola-m's Avatar
Datum registracije: Dec 2003
Lokacija: river una
Postovi: 413
Cooler je slične konstrukcije kao i onaj Asus Ice-kako se vec zove, a taj asus je jakojakojako loše prošao na testovima zbog velike buke i lošeg hlađenja. Tako da .....
nikola-m je offline   Reply With Quote
