Staro 14.03.2012., 09:23   #1
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Nvidia GeForce GTX680
Mislim da bi bilo vrijeme za zasebnu temu
GK104 Transistor Count and Exact Die-Size Revealed
A part of the reason why NVIDIA's performance-segment GK104 is gunning for the performance crown from AMD's Tahiti GPU could be hidden behind two of its key specifications: transistor count, and die-size. 3DCenter.org compiled these two specifications for the GK104 from reliable sources, which pin the transistor count at 3.54 billion, and die-area at 294 mm². This yields a transistor density of 12 million per mm², which is slightly higher than that of AMD Tahiti, slightly lower than that of AMD Pitcairn, and certainly higher than previous-generation chips from both AMD and NVIDIA. If GeForce GTX 680 does in fact end up competitive with AMD's Radeon HD 7900 series, it could serve as a tell-tale sign of NVIDIA's Kepler architecture being a more efficient one.
C L O W N I N G A R O U N D
Staro 18.03.2012., 16:04   #2
speoon
Lokacija: vukovar
Postovi: 57
speoon je offline   Reply With Quote
Staro 18.03.2012., 22:05   #3
Doink the Clown
Postovi: 6,214
Staro 19.03.2012., 10:40   #4
Doink the Clown
Postovi: 6,214
ASUS GeForce GTX 680 for Pre-Order in USA
Last week, a Dutch store solicited pre-orders of ZOTAC GeForce GTX 680 for a brief period, before redacting the sale page. It was priced at 507.18€ (incl. taxes). US retailer Bottom Line Telecommunications, listed ASUS GeForce GTX 680 on its online store (shopBLT). Carrying the part number GTX680-2GD5, this card is priced at US $566.75. The part that makes this a pre-order is that the sale page mentions that "You may order this product regardless of availability," it would be shipped as soon as it's available (after it's launched, of course). The page doesn't tell us anything about the GTX 680 that we don't already know.
Staro 19.03.2012., 14:08   #5
nexusone
Datum registracije: Apr 2008
Postovi: 139
evo i slikica Gigabyte-ovog modela: LINK
nexusone je offline   Reply With Quote
Staro 20.03.2012., 20:19   #6
Doink the Clown
Postovi: 6,214
Factory-Overclocked GeForce GTX 680 by MSI and EVGA get Listed
Evo i tvornički nabrijanih zvjerčica
North American retailer NCIX listed two factory-overclocked NVIDIA GeForce GTX 680 graphics card models. NCIX did not list these two for pre-order, but enabled "Add to Wishlist", which probably notifies those with the product in their wishlists of when they are in stock. Both cards are priced at US $578.20 (incl. free shipping to contiguous US states). The clock speeds of MSI's card, which carries the part number "N680GTX-PM2D 2GD5/OC" was revealed to be 1056 MHz (core) with 6 GHz (GDDR5 effective memory); while those of EVGA's card, which carries the part number "02G-P4-2682-KR", were not revealed. We know from its clearly-mentioned brand extension "SuperClocked", that it's factory-overclocked.
Staro 20.03.2012., 20:49   #7
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
http://www.xtremesystems.org/forums/...=1#post5071447
Procurilo
Nisam ovo ocekivao ni izdaleka :O
tole_ je offline   Reply With Quote
Staro 20.03.2012., 21:05   #8
rockodaddy
rockodaddy's Avatar
Datum registracije: Aug 2010
Postovi: 207
Autor tole_ Pregled postova
Procurilo
,Nvidia sorry na žuganju,my bad.
Learn to listen carefully to others' opinions about controversial things, or things they know about and you do not
rockodaddy je offline   Reply With Quote
Staro 20.03.2012., 21:05   #9
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
I izgleda da ce bit nekih 15,20$ jeftinija od 7970. Nije puno ali..
Staro 20.03.2012., 21:09   #10
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Like a boss rezultati, samo zajeb sa 2gb rama, tocno se vidi na 1600p kako pushi od 7970 radi manjka meme(C2 i B3), na 1080p ju sije zesce a na 1600p izjednacene ili gubi lagano. Cak i manje struje vuce od 7970 koliko sam vidio. Treba jos samo cijenu kod nas vidjet.
E da, i OC potencijal kakav ce imat.
Staro 20.03.2012., 21:15   #11
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Crysis 2 je jos zahtjevniji od BF3 po potrosnji vrama pa jos uvije 680 i solidno vodstavo. Samo dokazuje koliko je brutalna grafa da joj ni to ne smeta a za one koji hoce vise doci ce i 4gb pa ce valjda prestat svo to prigovaranje i izmisljanje tople vode. Vec se sad otvaraju teme da je fail zbog navodno loseg GPU computea sto je ionako jako relativna stvar .
Netko je na XS sumiro i u grubo +12% u 1080p sa aa i +8% u 1600p sa aa u bitnim igrama.
Spominju se cijene od 500$ sto znaci da mogla bit osjetno jeftinija od 7970, da bar..
Load noise veseli a ni temp ni previsoka.
Zadnje izmijenjeno od: MAGARAC. 20.03.2012. u 22:08.
Staro 20.03.2012., 22:51   #12
gnomisa
gnomisa's Avatar
Datum registracije: Feb 2003
Postovi: 1,556
Autor MAGARAC Pregled postova
Pa ja vrtim glatko na max valjda i najzahtjevniju igru (i u smislu vrama) bez beda na 1920x1200 na svojoj 470 TF2 koja ima mislim 1280 MB VRAMA....samo nemam upaljen HDR.....istina ta igra (Rise of flight) dobro koristi i RAM....
gnomisa je offline   Reply With Quote
Staro 21.03.2012., 00:35   #13
AlphaDog
AlphaDog's Avatar
Datum registracije: Dec 2010
Lokacija: Ri
Postovi: 37
BF3 mi cucla max 1500MB, a Crysis 2 nekih 1600-1650 u 1080P, znači ima još dobrog lufta za 1600P dok se ne popuni 2GB.
AlphaDog je offline   Reply With Quote
Staro 21.03.2012., 21:30   #14
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Staro 22.03.2012., 01:43   #15
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Staro 22.03.2012., 09:33   #16
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Autor AlphaDog Pregled postova
Preko 2gb videomemorije ždere bf3 u 1080p kad su postavke maxxane do kraja
Staro 22.03.2012., 11:20   #17
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
posto tweaktown iz nekog razloga nije pod NDA, evo malo preuranjenog reviewa
imajte strpljenja, ponekad im server steka
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 22.03.2012., 11:56   #18
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Autor antrax Pregled postova
Uglavnom preprestare igre u testu, uglavnom nvidia naklonjene igre rekao bih.
I da, temperature grafe su malo ovisoke, u odnosu na npr referentnu 7970.
Staro 22.03.2012., 12:56   #19
Doink the Clown
Postovi: 6,214
NVIDIA Releases the 301.10 WHQL Driver for the GeForce GTX 680
Since the GTX 680 will be launched later today, NVIDIA has decided to go ahead and publish the first (official) driver that supports its Kepler-powered card. Known as 301.10, this driver is WHQL certified, it only knows the GeForce GTX 680 (you'll need a modified inf file for 'expanded' support), and is bundled with the PhysX System Software v9.12.0213 (plus HD Audio v1.3.12.0).
GeForce 301.10 WHQL (Windows 7/Vista 32-bit) / GeForce 301.10 WHQL (Windows 7/Vista 64-bit)
The GeForce 301.10 includes the following highlights:
New Features
NVIDIA GPU Boost Technology - dynamically maximizes clock speeds based on workload of the game to push performance to new levels and bring out the best in every game.
NVIDIA FXAA Technology - shader-based anti-aliasing technology available from the NVIDIA Control Panel that enables ultra-fast anti-aliasing in hundreds of PC games. FXAA delivers similar quality to 4x multi-sample antialiasing (MSAA) but is up to 60% faster, enabling substantially higher performance in games. Note: This feature is disabled for games already have built-in support for FXAA.
NVIDIA Adaptive Vertical Sync - dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience.
NVIDIA Frame Rate Target - dynamically adjusts frame rate to a user specified target. Support for this feature is enabled via third party applications via NVAPI.
NVIDIA 3D Vision Surround Technology - with a single GeForce GTX 680 you can expand your PC games across three displays in full stereoscopic 3D for the ultimate "inside the game" experience. NVIDIA Surround also supports triple screen gaming with non-3D Vision monitors.
New Surround features:
- Add in a fourth accessory display to get access to your email, web, or other applications while you game.
- Maximize an application to a single physical display when in Surround mode (enabled by default).
- Confine the Windows Taskbar to the center display (enabled by default).
- Enable bezel peeking - a feature which enables users to temporarily 'peak' behind the monitor bezels using a hotkey (Ctrl + Alt + B). This feature is designed to be used in conjunction with bezel corrected resolutions.
- Enables users to add or remove resolutions from the list of Surround resolutions (only those selected will be available to applications).
- Enables full center display acceleration for single wide display modes (center display must be connected to the master GPU).
NVIDIA NVENC Support - adds support for the new hardware-based H.264 video encoder in GeForce GTX 680, providing up to 4x faster encoding performance while consuming less power.
http://www.techpowerup.com/162848/NV...e-GTX-680.html
Staro 22.03.2012., 14:15   #20
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Evo malo detaljniji review...
U 19 testriranih igri,
1920x1200 4AA 27.7% brza od gtx 580, 9.4% od 7970
1920x1200 8AA 24.7% brza od gtx 580, 9.8% od 7970
2560x1600 brza od 4% od 7970
Od 19 testiranih igri gtx 680 je sporija od 7970 u Metrou2033 i AvP..
Zadnje izmijenjeno od: MAGARAC. 22.03.2012. u 14:42.
Staro 22.03.2012., 14:17   #21
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,536
ove drivere možemo i mi na gtx 5xx? netko probao?
Staro 22.03.2012., 14:37   #22
Postovi: 8,241
Ja nemogu na 560ku, bar ne ove sa linka iz doinkovog posta.
Staro 22.03.2012., 14:43   #23
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
Autor Pupo Pregled postova
Bas sam provjerio nv_disp.inf i samo je gtx 680 u njemu. Mozda bi proradilo kad bi rucno dodali ostale graficke iz neke starije verzije drivera (copy paste iz starog nv_disp.inf u ovaj novi)
Staro 22.03.2012., 14:47   #24
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Ovome sto je radio recenziju rade i na gtx 580 i to poprilicno dobro u odnosu na 290.xx
"GTX 580 1.5GB and GTX 680, we are using the latest 300.99 drivers for testing, and compared to the 290 drive, 1.5GB GTX 580 300.99 BF3, 1920X1200 4AA average frame rate drive faster than the GTX 580 3GB 290 2.2%, but GTX 580 1.5GB 300.99 From the curve of the frame rendering time significantly more stable, and the visual is the most stable curve, but the specific average frame rate to speak of how we also need to quantify the frustration index and sensory."
Los je prijevod ali se valjda kuzi..
Staro 22.03.2012., 14:58   #25
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,536
ma pričekat ću valjda će dodat nove drivere i za ostale serije
Staro 22.03.2012., 15:07   #26
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
http://www.overclock.net/t/1232581/n...0-whql-drivers
http://www.hardocp.com/article/2012/...eo_card_review
http://www.hardwarecanucks.com/forum...gb-review.html
"After years of releasing inefficient, large and expensive GPUs, NVIDIA's GK104 core - and by association the GTX 680 - is not only smaller and less power hungry than Tahiti but it also outperforms the best AMD can offer by a substantial amount. A price that doesn’t break the $500 mark and undercuts the HD 7970 by some fifty bucks is just the icing on the cake. In our opinion, it is a true game-changer for the GeForce lineup since it bucks past trends and allows NVIDIA to essentially offer more for less. This card couldn’t have been released at a better time since AMD was not been able to ramp up HD 7970 production fast enough to meet demand, leaving many potential customers without cards and ready to embrace what NVIDIA is offering. In addition, the GTX 680 will force AMD's hand into lowering the prices of their high end lineup, making a whole generation of cards that much more affordable. "
Teze da je 2gb premalo sa ovim padaju u vodu. Grafe na maskimalnim igrivim postavkama sa tri monitora. U vecini igri je i ovdje brza od 7970...
http://www.hardocp.com/article/2012/...card_review/10
U svakom slucaju win!!
Zadnje izmijenjeno od: MAGARAC. 22.03.2012. u 15:35.
Staro 22.03.2012., 15:16   #27
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Techpowerup GTX 680
6% bolja od 7970, i nije nesto, tek toliko da mogu rec da su ispred, ali ajde, potrosnju su napokon sveli na razinu AMDa, cak i nize malo.
I shebali su sad manual OC sa ovim dinamickim OCom.
Zadnje izmijenjeno od: HCS. 22.03.2012. u 15:31.
Staro 22.03.2012., 15:25   #28
sapunko_HR
Datum registracije: Oct 2011
Lokacija: _
Postovi: 277
Ma GTX 680 owna
Jel se zna cijena? Nadam se da će barem naši trgovci nabit visoku cijenu,valjda će gledat performanse.
Dao sam puno za HD7950 i sad ako smanje neka mi vrati AMD,trgovac ili uvoznik sve ono šta sam preplatio.
Da li postoji kakva mogućnost žalbe udruzi potrošač ili?
sapunko_HR je offline   Reply With Quote
Staro 22.03.2012., 15:29   #29
lolofuxy
lolofuxy's Avatar
Datum registracije: Jun 2010
Postovi: 3,319
lolofuxy je offline   Reply With Quote
Staro 22.03.2012., 15:33   #30
mr Rockwell
mr Rockwell's Avatar
Datum registracije: Mar 2008
Postovi: 354
REDEFINE
SLEEVING HOW TO
mr Rockwell je offline   Reply With Quote
