Staro 17.07.2005., 14:20   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
PCI Latency Tool 2.3
Za ponosne vlasnike 6xxx serije ovo je koristan prog za smanjivanje ili potpuno eliminiranje stutteringa.
Inače se koristi i za eliminiranje problema sa nekim modelima zvučnih kartica.
Koristan prog kojeg bi svaki ozbiljniji tweaker morao imati integriranog.
Utility to set PCI Latency and possibly prevent game stutter or improve FPS. This tweak is an important one, and one well worth checking into. Apparently, newer high-end video cards hog PCI latency for no known reason. This makes other components wait for access and causes stutters and thus lower frame rates. If you adjust the latency this might benefit you, users are reporting big improvements. You can download this small utility program that allows you set your PCI latency. Adjust the PCI latency from for example 248 to 64, and there's a very good chance of stutter free performance & sound.
STEP 1. open the pci latency tool
STEP 2. Rightclick on your graphics card and click change setting(s)
STEP 3. change to desired setting and hit ok
Step 4. click settings and select apply at startup so it has a tick next to it
STEP 5. click settings and select save so everything you have just done is saved
STEP 6. right click on your video card and click quickset latency (if you want to set it straight away).
More information and user experiences can be found in this forum thread:
http://forums.guru3d.com/showthread....hreadid=121190
Skidanje:
http://downloads.guru3d.com/download...c13b5674e0dc22
Korisna stvar u samo 250kb
Staro 17.07.2005., 21:38   #2
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,541
Evo kako je kod mene po defaultu
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Zadnje izmijenjeno od: LAcy. 05.03.2007. u 23:53.
Staro 17.07.2005., 22:00   #3
Broken Arrow
The Man
Broken Arrow's Avatar
Lokacija: Novi Zagreb
Postovi: 1,252
Je li itko ovdje ovo probao
"Everybody's at war with different things...I'm at war with my own heart sometimes"
Broken Arrow je offline   Reply With Quote
Staro 17.07.2005., 22:44   #4
Brain32
Brain32's Avatar
Postovi: 498
Ja sam probal al' kod mene nije problem bio/je u grafi neg' u kolicini ram-a, kol'ko sam ja skuzil to najvise efekta ima kod ekipe s 6800 grafama
Meni je po defaultu sve(grafa,AGP i modem) na 32 a ostalo na 00
Brain32 je offline   Reply With Quote
Staro 17.07.2005., 23:12   #5
Broken Arrow
The Man
Postovi: 1,252
Evo ga i sve je u redu još samo da probam u cod-u i wow-u
Pod latency piše 248 ,a pod new latency 064
EDIT:
Ipak mi se čini da se bolje ponaša kada je na 128 nego kada je na 64 ,pa sam zato ostavio na 128
EDIT 2:
Razlike u cod-u i nema ,ali u wow-u se dosta vidi
Zadnje izmijenjeno od: Broken Arrow. 18.07.2005. u 01:09.
Staro 18.07.2005., 15:16   #6
Jelc
Super Moderators
Postovi: 17,485
A jebem te ludog
Ti imaš PCI-E grafu, to šljaka samo na AGP i PCI uređajima.
Dosta ljudi koji imaju npr. LIVE seriju zvučnih su riješili probleme sa tim progom.
Staro 18.07.2005., 15:19   #7
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,541
A jebga sto nisi rekao ranije
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 18.07.2005., 15:42   #8
Jelc
Super Moderators
Postovi: 17,485
I ja sam se sjetio tek danas
