Staro 16.07.2005., 11:17   #1
spawn
spawn's Avatar
Postovi: 8,372
Kako se rijesiti zastite na WMA fajlovima?
Naime,klijent je kupio novi PC i prebacio svu muziku na novi komp,i sada trazi licencu za slusanje. Muziku je prije sam sa CD-a ripao na hard pomucu WMP.
Hvala
Staro 16.07.2005., 19:45   #2
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Sve mu pise u helpu od WMP-a:
Copy protect music Specifies whether tracks copied from CDs in Windows Media Audio format are protected files. A license is required to play protected files. Licenses help protect the copyrights of artists by preventing illegal distribution. Selecting this check box may prevent you from playing the tracks on another computer.
Note
You should back up your licenses to a floppy disk periodically. If you reinstall or upgrade your operating system, your licenses could be lost even though you retained your protected files.
Na WIN pod kojima je ripao glazbu treba pokrenuti WMP i izabrati Tools > Manage Licenses i tamo kopirati licencu pa je na isti nacin ucitati na drugim WIN.
Ako nema pristup licenci onda mu preostaje ponovno ripanje samo drugi put ce valjda biti pametniji pa malo prouciti gradivo
