Staro 12.01.2012., 15:44   #1
T0mB1ll
420
T0mB1ll's Avatar
Lokacija: Le Molve
Postovi: 1,577
Corsair Carbide 300R
T0mB1ll je offline   Reply With Quote
Staro 14.07.2012., 20:20   #2
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Corsair Carbide Series 300R Available in Windowed Version
Corsair, a worldwide designer and supplier of high-performance components to the PC gaming hardware market, today announced that the Carbide Series 300R Compact PC Gaming Case is now available in a windowed version.
First released in January, the Carbide 300R PC case has won accolades for its compact, streamlined, builder-friendly design. The new Carbide Series 300R windowed version of the case of features a side window that gives PC builders the ability to demonstrate their modding skills while also showcasing internal PC components, such as Corsair's PC performance tuned Vengeance DDR3 memory, GS Series power supplies, Hydro Series CPU coolers, and Air Series cooling fans.
The Corsair Carbide Series 300R: a compact expression of Corsair's gaming PC philosophy
Great gaming systems begin with a great case, and the Carbide Series 300R provides a remarkable number of in-demand features in an attractive, compact chassis. Builder-friendly features include three tool-free optical drive bays and four tool-free hard drive bays with integrated 2.5" SSD compatibility. There's room for high-end GPUs of up to 450mm in length, and the matte black interior incorporates Corsair's innovative cable routing system that helps keep wires and cables out of sight for a clean look and improved airflow. The 300R comes with intake and exhaust fans, with room for five additional fans including dual side-mounted fans for direct GPU cooling.
http://www.techpowerup.com/168938/Co...d-Version.html
C L O W N I N G A R O U N D
Staro 14.07.2012., 20:23   #3
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Lijepo izgleda, svida mi se
Staro 14.07.2012., 23:49   #4
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
Tko ce dati 700kn za ovaj kejs kad se za 800 uzme 500r? Kod nas je 300r cini mi se solidno precijenjen.
tole_ je offline   Reply With Quote
Staro 15.07.2012., 08:38   #5
Postovi: 34,040
Još jedan kavez za hardove mu ne bi došao loše. Kod nas će sigurno biti precjenjen u razini cijene od 100 EUR.
