Staro 09.01.2012., 22:11   #1
keyser_s()ze
Postovi: 590
Logitech g400 nema više korekcije/predikcije/itd.
http://forums.logitech.com/t5/G-seri.../763727/page/2
"Angle snapping was removed as of PID LZ13333. Lower PIDs have angle snapping.
There is no way to specify in online orders which version you are going to get. As time goes on, it is more likely that you will receive a non-angle-snapping version as stock of the older version is depleted.
In retail stores, you can tell the difference between the older and newer versions by the package's transparent closure labels; G400s without angle snapping have the Logitech logo printed on these labels. G400s with angle snapping have no printing on these"
Po meni prilično bitna stavka prilikom odabira miša. Moj savjet je pričekat dok ne dođu ovi novi kod nas (ako već naravno nisu došli).
keyser_s()ze je offline   Reply With Quote
Staro 09.01.2012., 23:23   #2
domis
Lokacija: Hrvatistan
Postovi: 4,165
moj PID je LZ13723, kupljen u linksu par dana nakon Božića...
znači, dobro sam prešel?
Staro 10.01.2012., 00:00   #3
Facelessone
Facelessone's Avatar
Postovi: 4,205
Dajte pojasnite o čemu se tu točno radi.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 10.01.2012., 09:32   #4
keyser_s()ze
Postovi: 590
Kažu da je slika vrijedna tisuću riječi...
Korekcija/prediction/angle snapping/drift control su zapravo jedna te ista stvar, razlika je samo u tome što je svaki proizvođač osmislio svoj naziv za taj "feature" (korekcija je moj slobodni prijevod). U osnovi miš sa korekcijom djelomično predviđa koji je pokret rukom korisnik htio napravit, te ga ovisno o ugrađenom algoritmu ispravlja.
Napravio sam usporedbu stare verzije g400 koji je dolazio sa uključenom korekcijom i microsoftove legende wheel mouse optical (oni koji duže igraju cs znaju koji je to miš. Za primjer povukao sam par bezznačajnih linija u paintu "istim" pokretom ruke, iz kojeg se jednostavno vidi o čemu se radi.
Sa mišom bez korekcije dobio sam blago krivudave pravce (donja polovica slike), dok su isti sa korekcijom gotovo potpuno ravni (gornja polovica slike). Ako usporedimo ovaj primjer sa crtanjem linije olovkom po običnom papiru sa i bez ravnala, možemo zaključit da je miš sa predviđanjem izvršio "korekciju" dobivenog inputa, tj. pokreta ruke.
Važno je napomenuti da zapravo svi optički i kvazi laserski miševi imaju određenu "količinu" korekcije koja eliminira nepravilnosti u korištenoj podlozi, budući da niti jedna podloga nije apsolutno ravna. Na primjer bez korištenja iste, na prosječnoj platnenoj podlozi, strelica miša poskakivala bi po ekranu kao pijani atletičar
Količina korekcije ovisi o korištenom senzoru, ali i samoj implementaciji proizvođača. Neki miševi dopuštaju uključivanje/isključivanje korekcije bilo putem drivera, pomoću flash-a novog firmware-a ili čak promjenom postavki na samom mišu.
Osobno mislim da je korekcija stvar navike i osobne preferencije, budući da korisnika i nezna za ovaj pojam. Ima slučajeva kad smeta kao buha u vruće ljetno popodne, a ima i slučajeva kad dobro dođe...
Za one koji žele znati više, kao početnu točku preporučam http://www.esreality.com/?a=post&id=2024663. Među linkovima može se naći dobrog šmokljan štiva...
Staro 10.01.2012., 17:13   #5
Buger
Postovi: 4,398
Zove li se to čudo u Setpointu "Smart Move"?
Staro 10.01.2012., 23:06   #6
keyser_s()ze
Postovi: 590
ako se ne varam smart move je isto što i snap to opcija u control panelu pod miševima. ta opcija za isključivanje trebala bi bit dostupna samo za miševe sa avago 9500 senzorima (ovim laserskim što imaju preko 5k dpi).
