Staro 30.12.2011., 21:06   #1
lujito
lujito's Avatar
Lokacija: Near
Postovi: 416
Softwer za glazbu na više audio kanala
Imam spojene zvučnik na laptop preko 3.5 mm jack-a i slušalice preko USB-a.
Postoji li nekakav softver koji podržava puštanje 2 pjesme istodobno, s tim da ja odaberem koju želim na slušalice a koju želim na zvučnike?
lujito je offline   Reply With Quote
Staro 30.12.2011., 21:09   #2
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
u programu preko kojeg pustas u optionsima samo odaberes preko kojeg izlaza hoces npr.
foobar #1 billy idol (3.5 mm jack)
foobar #2 ray charles (usb )
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline   Reply With Quote
Staro 30.12.2011., 21:18   #3
lujito
lujito's Avatar
Lokacija: Near
Postovi: 416
Autor fre@k Pregled postova
Da, evo progooglao sam rješenje za Windows Media Player, pa možda nekome pomogne.
Yes, it is possible to hear two different songs from the laptop with the kind of configuration that you have, if you play one song on Windows Media Player and other song on a different player.
To do this, follow the given steps:
a. Play a song on a 3rd Party Player and verify which Audio Output is it using (if its HDMI output from TV or the laptop Audio output).
b. 1. Open Windows Media Player, click on tools.
2. Click on Options.
c. Click on Devices tab and select Speakers.
d. Click on properties button and then click on the drop down menu under "Select the audio device".
e. Choose the other Audio output for Windows Media player, click on Apply and then click on Ok.
f. Try playing the song and check if you can hear two different songs at a time from different Players.
Pokušao sam u Winamp-u nać opciju, nisam uspio, vjerojatno nisam dovoljno dobro tražio.
Staro 30.12.2011., 21:29   #4
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
ima i u winampu
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
