Staro 02.07.2005., 13:01   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ForceWare 80.40 Win2000/XP (beta)
Procurila je nova beta, ima par zanimljivih stvari-podrška za nove modele 7xxx serije, za H.264, driveri podržavaju sve od GF2 na gore.
Quite an interesting new ForceWare driver appeared on 3DChipset today. This 80.40 version adds H.264 hardware decoding to the 7800 series (new sort of MPEG codec) . What's interesting is their is no version number presented in the nv4_disp file. Plus some new entries are apparent in this release too. The C51 chipset by NVIDIA as well as a G72?
The drivers seem to be valid, have been virus checked and recrunched. They are now 11 MB in size. The files in the archive are dated June 13th.
Almost any geForce graphics card to date is supported in these drivers. Again, props to 3DChipset for posting these.
Version Notes:
nv4_disp lists - DriverVer = 06/13/2005 ; Changelist 1300631
Adds H.264 hardware decode support for the 7800 series
Drivers come with a setup.exe for easy installing
GeForce 2 and up are supported in this release
Files are dated: June 13th, 2005
WinZip Packaged
New Entries:
NVIDIA_G72.DEV_01D0.1 = "NVIDIA G72"
NVIDIA_G72.DEV_01D1.1 = "NVIDIA G72"
NVIDIA_G72.DEV_01D2.1 = "NVIDIA G72"
NVIDIA_G72.DEV_01D3.1 = "NVIDIA G72"
NVIDIA_G72.DEV_01D5.1 = "NVIDIA G72"
NVIDIA_G72.DEV_01DE.1 = "NVIDIA G72GL"
NVIDIA_G72.DEV_01DF.1 = "NVIDIA G72"
NVIDIA_C51.DEV_0240.1 = "NVIDIA C51GL"
NVIDIA_C51.DEV_0241.1 = "NVIDIA C51"
NVIDIA_C51.DEV_0242.1 = "NVIDIA C51"
NVIDIA_C51.DEV_0243.1 = "NVIDIA C51"
NVIDIA_C51.DEV_0244.1 = "NVIDIA C51"
NVIDIA_C51.DEV_0245.1 = "NVIDIA C51"
NVIDIA_C51.DEV_0246.1 = "NVIDIA C51"
NVIDIA_C51.DEV_0247.1 = "NVIDIA C51"
NVIDIA_C51.DEV_0248.1 = "NVIDIA C51"
NVIDIA_C51.DEV_0249.1 = "NVIDIA C51"
NVIDIA_C51.DEV_024A.1 = "NVIDIA C51"
NVIDIA_C51.DEV_024B.1 = "NVIDIA C51"
NVIDIA_C51.DEV_024C.1 = "NVIDIA C51"
NVIDIA_C51.DEV_024D.1 = "NVIDIA C51"
NVIDIA_C51.DEV_024E.1 = "NVIDIA C51"
NVIDIA_C51.DEV_024F.1 = "NVIDIA C51"
Please consider this driver to be extremely BETA !! You use it at your own risk. If things mess up ... hey that's the risk you took.
http://downloads.guru3d.com/download.php?det=1116
Staro 03.07.2005., 14:39   #2
Brain32
Brain32's Avatar
Postovi: 498
Je, probal sam ih al su mi nekak cudljivi, poboljsanja nad 77,72WHQL nema ili bar nema znacajnih...
Naj cudnije je kaj mi je 3dm2005 dao cca isto mark-ova dok u 2001 dobivam skoro 1000 manje!?
Brain32 je offline   Reply With Quote
Staro 03.07.2005., 15:01   #3
Jelc
Super Moderators
Postovi: 17,485
Probaj očistiti ostatke starih drivera.
http://www.drivercleaner.net/
Makar-driveri su zanimljivi samo zbog par điđa za nove grafe i čisto ti daju uvid u buduće modele 7xxx serije koje do sad još nisu najavljivali...
Staro 03.07.2005., 15:18   #4
Brain32
Brain32's Avatar
Postovi: 498
Jesam, bas sam ga nedavno skinul(i cab-ovi su ocisceni).
A vjerojatno je neka piz**rija u pitanju...
Ne bi to ni primjetil al sam se ovih dana malo "igrao" s grafom i procom pa ono... instaliral sam si par Markova,Sandricu itd.
BTW: OpenGL je iso jako fino s njima(Pacific Fighters +2fps u odnosu na 77.72)
Staro 03.07.2005., 16:12   #5
Jelc
Super Moderators
Postovi: 17,485
Meni je mjerilo korištenje AA i ANISO za igre koje najviše igram.
Ako je manji minimalni fps i ne pada ili je malo veći prosjek-dobri su
Za benchanje je tak i tak bolje imati dual-boot, čisti OS i najbrže drivere za objesit rezu na futuremark.
Staro 05.07.2005., 00:19   #6
Newbie Pro
Zule
Newbie Pro's Avatar
Postovi: 1,993
Bok, imam pitanje vezano uz ForceWare drivere:
Imam u starom kompu GeForce2 MX400, WinXP, i zadnji driveri koje sam koristio su Detonator (nemam pojma koji). Sad, da li podržavaju ForceWare driveri i GF2 MX serije? I što se desilo s legendarnim Detonatorima?
Totalni sam nVidia noob, što se drivera tiče, trenutno se zajebavam s ATI karticama
Thx
Newbie Pro je offline   Reply With Quote
Staro 05.07.2005., 00:24   #7
Broken Arrow
The Man
Broken Arrow's Avatar
Lokacija: Novi Zagreb
Postovi: 1,252
Thx
ForceWare su zamjena za Detonatore (nažalost jel po meni odkad su došli ForceWare to nije to)
I da ForceWare podržavaju sve grafulje od GF2 nadalje
"Everybody's at war with different things...I'm at war with my own heart sometimes"
Broken Arrow je offline   Reply With Quote
Staro 05.07.2005., 00:27   #8
Newbie Pro
Zule
Newbie Pro's Avatar
Postovi: 1,993
Thx, ovo je fakat bilo brzo
Zakaj kažeš to nije to?.. Znam da su prije Detonatori svakom novom serijom bili sve brži i brži
Staro 05.07.2005., 00:36   #9
Broken Arrow
The Man
Postovi: 1,252
Ma ne kažrm da ForceWare ne valjaju nego to više nisu oni nvidijini kompletni driveri koji su bili bez ikakvih problema ,pogotovo ovi novi koje moraš tweakat da bi došao do "naprednijih" (ustvari osnovnih) opcija
Sve su ti to presudne nijanse...
Staro 05.07.2005., 00:39   #10
Newbie Pro
Zule
Newbie Pro's Avatar
Postovi: 1,993
Aaa... Ma budem ih stavio, ovi su Detonatori brijem stari par godina, a ipak u mreži znamo i CoD bacit, svaki frame viška je dobrodošao
Thx
Staro 05.07.2005., 00:43   #11
Broken Arrow
The Man
Postovi: 1,252
Sada ne znam je li ti to pametno jel su što noviji driveri optimizirani samo za nove grafulje pa tako da su najbolji driveri za npr. ti4200 oni 41.xx ,a za gf2 ti stvarno ne bi znao...
Probaj pa ako su ti novi bolji ostavi ih ,a ako ne vrati stare/starije
Staro 05.07.2005., 13:17   #12
Brain32
Brain32's Avatar
Postovi: 498
Po mom iskustvu 45.23 je najbolji driver za: TNT2,GF2MX,GF4MX,FX5200. Sve te kartice su prosle kroz moje ruke ali zadnja(fx5200) prije cca.1.5god tak da ne znam dal to jos uvijek stoji ali ih u svakom slucaju preporucujem...
