LateralusX
Postovi: 1,788
Nvidia Forceware v290.36 beta driveri
GeForce 290.36 Beta DriversThis is the first beta release from the Release 290 family of drivers.You can read more about this family of drivers on GeForce.com. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, 400, and 500-series desktop GPUs as well as ION desktop GPUs. New in R290 Drivers NVIDIA PhysX Updates PhysX System Software to version 9.11.11.07 for the best PhysX experience in Batman: Arkham City. NVIDIA SLI Added or updated SLI profiles for Crysis 2, Heroes and Generals, Inversion, Stronghold 3, and Syndicate. HD Audio Updates HD Audio driver to version 1.3.9.0. Some Key Bug Fixes Fixes random flickering as Windows boot logo is loading or fading away. Fixes corruption in Crysis 2 with SLI and lower quality shadow settings. Fixes corruption seen in Settlers 7 with 275.33 drivers. Other Details Supports single GPU and NVIDIA SLI technology* on DirectX 9 and OpenGL. Users without US English operating systems can select their language and download the International driver here. *Note: The following SLI features are only supported on Windows Vista and Windows 7: Quad SLI technology, 3-way SLI technology, Hybrid SLI, and SLI multi-monitor support. |
ODUZIMAM VAM RIJEČ
Postovi: 13,503
kada alt tabam u bf3 i vratim se nazad u igru, rezolucija se svaki put promjeni na 960x1200 (sa 1920x1200) :S
LateralusX
Postovi: 1,788
#9 | |
Postovi: 7,697
Dogodilo se to meni. Problem je msi afterburner zadnja beta. Na destopu bila obavjest i pisalo mu je da će prestati raditi 27.11.2011. Bilo je teško deinstalirati. Pa sam na neki način uspio službenu verziju instalirati i radi dobro kako treba
__________________ |
#10 | |
LateralusX
Postovi: 1,788
LateralusX
Postovi: 1,788
#15 | |
Postovi: 1,011
Evo ciko skinio ovu betu na poslu pa cu si na stiku ponjet kuci da probam, kad sam ostao bez neta kod kuce ![]() Inace nebi skidao, ali kod kuce sam na nekoj staroj verziji, 260 nesto, valjda i shvatih da mi SLI u skyrimu neradi kako spada, jedna grafa na 100% zauzeca, druga rjetko samo skoci do 10%. Sutra javim ima li pomaka. Mislim da je profil za SLI u skyrimu dodan u 280 i nesto verziji. OT: Zanimljivo je da obje grafe uvjek imaju istu kolicini zauzete memorije u megabajt, u windowsima 80-150MB, skyrim 1300+MB. Znaci nije, kako neki kazu, da memorija druge zjapi nezaposlena, a i nema se duplo vise momorije. EDIT: Normalno, nisam juce stigao ni komp upalit, a ne instalirat drajvere ![]() Zadnje izmijenjeno od: Momir. 02.12.2011. u 13:16. |
#18 |
Postovi: 1,011
Evo ja probao, prvo se nisu htjeli instalirati, pa ja porobao ponovno i onda prosla instalacija bez problema, neznam sta im bi. Za sad skyrim i windowsi rade kako spada. Graficke u SLI sad obje budu zauzete oko 60-70% i minimalni fps je do sad bio nekih 25, a sad malo manje od 50 fps-a. |
#20 |
eto, 5 dana korištenja i za sada nikakvih problema. nadam se da će tako ostati. samo sam postavio pod Global Settings - maximum power consumption ili kak već piše i radi najnormalnije, čak i malo OC-ana u Afterburneru. |
#22 |
Meni se čini da je meni više problema zadavao Afterburner 2.1.0. Otkako sam skinuo 2.2 beta 9 i pobrisao PnkBstrA.exe i PnkBstrB.exe, nema nikakvih problema na taktovima 900/1800/2200 sa defaultnom voltažom. Nisam pokušavao to sa 285.xx driverima tako da ne znam jel se to popravlja, ali eto, već tjedan dana vozim ove, odigrao sam Call of Pripyat, Battlefield 3 i Half-Life 2 - Cinematic mod (dakle nekih 40 sati gameplaya) i nikakvih problema nisam imao, niti flickering, niti trzanja, niti rušenja drivera. |
#24 | |
#25 |
Datum registracije: Dec 2011
Lokacija: zagorje/zg
Postovi: 47
vratio na 285.62 i sad je bolje... |
