Datum registracije: Nov 2011
Lokacija: Vž
Postovi: 48
High-end ventilatori [12cm]
Prošlo je podosta vremena od kad se zadnji put pričalo o ventilatorima s kontrolom okretaja, tehnologije su napredovale, novi proizvodi su na tržištu. U nastavku pogledajte tehničke karakteristike nekih od ventilatora koji pružaju kontrolu vrtnje, nisku razinu buke i viski stupanj protoka zraka. Pošto IRL ne mora biti onako kako je zapisao proizvođac, treba testirati. Uglavnom evo popisa: ARCTIC F12 Max Noise: n/a - 25dBA Fan speed: 400 - 1350RPM Airflow: 74CFM Warranty: 6yr Scythe "KAMA PWM" Noise: n/a - 24.89dBA Fan speed: 310 - 1200 RPM Airflow: 12.38 - 52.71 CFM Life Expectance: 30,000 hrs Coolermaster Excalibur Noise: 13 - 30 dBA Fan speed: 600 - 2000 RPM Airflow: 26.4 - 85.6 CFM Life Expectance: 100,000 hrs Enermax UCTB12P Noise: 8 - n/a dBA Fan speed: 500 - 1,500 RPM Airflow: 26.51 - 71.25 CFM Life Expectance: 100,000 hrs Nexus D12SL-12 PWM Noise: 15.5 - 26,9 dBA Fan speed: 500 - 2000 RPM Airflow: n/a - 76 CFM Life Expectance: n/a Akasa Viper PWM Noise: 6.9 -28.9 dBA Fan speed: 600 -1900 RPM Airflow: n/a - 83.63 CFM Life Expectance: 50,000 hrs Cooler Master Blade Master Noise: 13 – 32 dBA Fan speed: 600 - 2000 RPM Airflow: 21.2 - 76.8 CFM Life Expectance: 40,000 hrs Coolink SWiF2-120P Noise: 8.5 - 27.1 dBA Fan speed: 800 - 1700 RPM Airflow: 35.6-75.1 CFM Life Expectance: n/a Gelid Solutions Wing 12 PL UV Reactive Noise: 10 - 26.8 dBA Fan speed: 600 - 1800 RPM Airflow: n/a - 75.6 CFM Warranty: 3yr Noiseblocker NB-Multiframe M12-P Noise: 12 - 29 dBA Fan speed: 1000 - 2000 RPM Airflow: 43 - 78 CFM Warranty: 6yr Scythe Kaze-Jyuni Slip Stream Noise: 7.05 - 37 dBA Fan speed: 470 - 1900 RPM Airflow: 23 - 110 CFM Life Expectance: n/a Noctua NF-F12 PWM Noise: n/a - 22.4 dBA Fan speed: 300 - 1500 RPM Airflow: 54,97 CFM Warranty: 6yr
ヽ(´ー`)ノ Zadnje izmijenjeno od: dropTable. 27.11.2011. u 16:33. |
Postovi: 8,244
Dobar je popis, ali bi trebalo stalno nadopunjavati bazu jer ventilatora ima puno puno više na tržištu. Možda bi bilo zgodno da naznačiš koji su dostupni kod nas!
Sent from AS/400. |
Lokacija: Vž
Postovi: 48
ヽ(´ー`)ノ |
gadget freak
Lokacija: Jasenovac
Postovi: 2,224
Datum registracije: May 2009
Postovi: 389
http://forum.pcekspert.com/showthread.php?t=185602 http://forum.pcekspert.com/showthread.php?t=222182 Dodaj rađe tamo da se ne razvodni sad na 100 mjesta, a već i ima. |
Lokacija: Zd
Postovi: 4,762
Kad se vec pise o high-end ventovima, mozda bi bilo dobro nadopisati iznos statickog pritiska, posto je to jedna od vaznijih karakteristika kod hladjenja cpu-a ili stvaranja negativnog tlaka unutar kucista... |
Postovi: 8,244
Eo malo rezultata s testa sa pravom opremom u realnim uvjetima. ![]() izvor: XS Zanimljivo kako neki jeftiniji ventovi poput F12 stoje jako dobro na ljestvici, dok neki skupi i razvikani modeli podbacuju u testovima.
Sent from AS/400. Zadnje izmijenjeno od: Pupo. 28.11.2011. u 16:57. |
