Staro 21.11.2011., 21:33   #1
Brown Acid
..dno
Brown Acid's Avatar
Lokacija: Crikvenica
Postovi: 1,973
Reprogramiranje biosa - gdje?
Posjedujem jedan HP 6715b kojem je oštećen bios pri updateu.
Postoji li neki forumaš koji se bavi reprogramiranjem biosa ili neka tvrtka koju bi preporučili?
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.”
Brown Acid je offline   Reply With Quote
Staro 21.11.2011., 23:19   #2
gil
Member
Lokacija: Kutina
Postovi: 979
Autor Brown Acid Pregled postova
Imam takav laptop ali zbilja ne znam kako mu je montiran bios čip. Ako je zalemljen onda treba odlemiti čip sa ploče a ako je umetnut u podnožje što čisto sumnjam onda je stvar vrlo jednostavna isčupaš bios iz podnoža i odneseš ga kod nekog tko ima eprom programator. Prošao sam to s nx9005 prije jedno 5-6 godina. Prvo pipanje s izlemljivanjem pa zatim programiranjem pa opet lemljenje ali valja probati ako nije skup majstor. Ovaj moj se time više ne bavi.
gil je offline   Reply With Quote
Staro 21.11.2011., 23:43   #3
domy_os
domy_os's Avatar
Postovi: 18,928
Jesi li probao recovery?
HP Compaq Commercial Notebooks SBIOS Recovery Procedures:
Quick synopsis:
There are two special keys Windows Key+B or up key+down key+left key+right key to use for this recovery processes.
Below are the step by step procedures to perform the recovery
1) Make sure power is off
2) Make sure AC Adapter is plugged in.
3) Plug in a USB floppy drive with floppy disk that contains only one binary file (
for example: 68ytt.bin for nx6125/nx6115, 68tt2.bin for nx6325/nx6315, or
the correct binary file for your series of HP Compaq Commercial notebook )
4) Press Windows Key+B (or all 4 directional keys)
5) Press power button (to power on the system)
6) Don't release the Windows key+B (or 4 directional keys) until floppy is
turning and running for a period of time.
7) If floppy is turning and running for a period of time then you can release the
keys and it must be doing the recovery already.
8) When it is doing the recovery, you'll notice that num-lock LED is constantly
flashing.
9) When it is finished flashing the bios, the system will reboot itself.
10) Don't do anything right now and wait until HP logo shows up because it will do
several reboot to update KBC ( Key Board Controller )....
11) Voila! you've got your system updated with newest BIOS....when see HP logo
press F10->restore to default->check the system info for BIOS version.
If system cannot be resurrected, it means that the BB ( Boot Block ) inside the ROM
chip has been destroyed. The only way to reflash the BIOS is to remove the ROM
chip from the motherboard and use an external BIOS ROM programmer to program
the BIOS content again.
How to get the System BIOS binary file.
The easiest ways is to get a ROMPaq version of the System BIOS for your notebook
and following the steps below;
1. Double click the downloaded SPXXXxx.exe file.
2. File Download – Security Warning window pops up and then Click Save.
3. Select the location where you want to save this ROMpaq file.
4. After download complete, select Open Folder
5. Double click SPXXXXX.exe to bring up Open File – Security Warning window
and then select Run.
6. Follow the on-screen instructions to generate a folder to hold all the files.
7. Open this folder and locate a WinZip file. Inside this zip file, you need to
extract all the files and the Rom.bin is the binary file you need for this
recovery process.
Hope this helps.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 21.11.2011., 23:57   #4
gil
Member
Lokacija: Kutina
Postovi: 979
Jel to radi na ovim starim hp kantama?
Staro 22.11.2011., 00:02   #5
domy_os
domy_os's Avatar
Postovi: 18,928
Valjda, nisam probao.
Staro 22.11.2011., 14:48   #6
Brown Acid
..dno
Brown Acid's Avatar
Postovi: 1,973
Nisam Domy..naišao sam na to ali nemam nikoga tko bi mi posudio usb disketar, bas sam se raspitivao medju ekipom ali nista..a ako ga kupim to je opet 200kn manje ako mi ne upali ta metoda.
Staro 22.11.2011., 21:09   #7
domy_os
domy_os's Avatar
Postovi: 18,928
Imam ja USB disketaru, ali nemam s*ebani notebook, a svoj ne diram...
Staro 22.11.2011., 23:44   #8
Alvin
Postovi: 853
Ako se ne snađeš javi se na pm,pa ako imaš koga ko će ti zalemit, poslat ću ti isprogramiran čip
Alvin je offline   Reply With Quote
Staro 24.11.2011., 01:11   #9
Brown Acid
..dno
Brown Acid's Avatar
Postovi: 1,973
Autor domy_os Pregled postova
Dofurao bi ti ja svog da si blize pa eksperimentiraj, ovako..nista.
Narucit cu usb disketar iz kine preko ebay-a za 50-ak kn pa cu sam probati.
