Staro 08.11.2011., 20:51   #1
vranjba
vranjba's Avatar
Datum registracije: Aug 2009
Postovi: 613
test wi-fi kartica
Malo mi je komp bio preko vikenda van pogona pa sam se malo poigrao sa laptopom i wi-fi katricama i napravio mali test jačine signala i dometa.
laptop: acer trevelmate 2410 i njegova ugrađena antena
mini pci wi-fi kartice korištene u testu:
msi - ralink rt2560f
broadcom bcm94306plna
atheros ar5005g
atheros ar5bmb5
Intel PRO/Wireless 2200BG
Ambit T60H424
evo rezultata
atheros ar5005g
atheros ar5bmb5
broadcom bcm94306
Ambit T60H424
udaljenost mreža
osa - 1 metar od laptopa
amput.... - oko 40 metara od laptopa, dvije kuće dalje
bran.. - oko 40 metara od laptopa, dvije kuće dalje
ostale mreže nepoznata lokacija
U ovom testu nije pokušavano nikakvo probijanje passworda niti neke druge nelegalne radnje
CPU: AMD Phenom II X2 545 @X4 B45 + AC Freezer 64 Pro PWM
MBO: Asrock a780GXH @ bios 1.70
RAM: Kingmax 2x2GB PC2-8500
VGA: Sapphire HD5570 1GB
Zvučna: Asus xonar d1
HDD: WD6401AALS + WD2000JB + WD3200AAJS
PSU: Corsair cx400W
Case: Gigabyte GZ-X6
Keyboard: Logitech mk520 + Microsoft Natural Wireless Mouse 6000
Daljnski: Mce ir
Zvučnici: Swans d1080mkii 08
Monitori: Philips 220SW + HP L1950g
TV: Panasonic TX-P50C3E
AIO: HP Deskjet F4280
OS: Windows 7 x64
HP Compaq nx7010
CPU: Pentium centrino 2.0 GHz
RAM: 1gb + 512mb PC2700
VGA: ATI Mobility Radeon 9200 32mb
HDD: wd 40 GB
OS: Win XP SP3 x32
CPU: Pentium 3 1.0 GHz + Glacialtech igloo 2520
MBO: Intel D815EFV
RAM: 2x 256mb PC133
HDD: Maxtor 80gb + Seagate Barracuda 7200.7 160gb
PSU: Codegen 400W
OS: Win XP SP3 x32
PCI Lan: Linksys cisco gigabit EG1032 v3
Routher: Thomson ST780i WL
Net: T-com Flat
Acernote lite 350pc
CPU: Pentium 100 MHz
RAM: 8 mb edo onboard
VGA: chips&tech f65545
HDD: ibm 540 mb
OS: win 95
CPU: pentium 166 MHz
MBO: ga 586vx rev 3.37
RAM: 4x16 mb edo ram
VGA: Ati 3D rage II +dvd 4 mb
HDD: quantum fireball se2.1a 2.1 gb
PSU: seasonic ssa-200g
Monitor: Acer 13"
OS: dos 6.22
vranjba je offline   Reply With Quote
Staro 08.11.2011., 23:28   #2
Postovi: 23,534
Šteta da nisi nivoe signala zabilježio sa NetStumbler ili inSSIDer - om jer bi dobio preciznije i razumljivije rezultate od ovog prikaza iz winsa.
Rezultati me nisu iznenadili, jedino pitanje / prijedlog za Atheros kartice koristi drajvere sa atheros.cz kad možeš jer su često bolji od onih koji se službeno distribuiraju.
Staro 09.11.2011., 00:36   #3
nino
nino's Avatar
Postovi: 12,613
broadcom rula. Fino je ovako test napravit.
Staro 09.11.2011., 08:33   #4
vranjba
vranjba's Avatar
Postovi: 613
koristio sam drivere sa www.wireless-driver.com
ovo mi je bilo najlakše, ali dobro bi bilo da se brojčano vidi jačina signala, nisam znao za ove programe, možda kad uhvatim vremena s njima zabilježim
da broadcom rula, šteta što ga ne mogu u svoj lap ubacit
PSU: Corsair cx400W
Daljnski: Mce ir
OS: Windows 7 x64
HP Compaq nx7010
HDD: wd 40 GB
OS: Win XP SP3 x32
MBO: Intel D815EFV
RAM: 2x 256mb PC133
PSU: Codegen 400W
OS: Win XP SP3 x32
Net: T-com Flat
Acernote lite 350pc
HDD: ibm 540 mb
OS: win 95
Monitor: Acer 13"
OS: dos 6.22
Staro 09.11.2011., 11:45   #5
Postovi: 23,534
Ta Broadcom kartica je poznata i pod "Broadcom Dell TrueMobile 1300 WLAN Mini-PCI Card" imenom i kao dobra kartica.
Za Atheros, ne navijam posebno ali, sa gore navedenim drajverima bi trebao imati i bolje retultate.
Još jedan važan detalj a bitan za testiranje je "držanje" wireless linka.
Sve će radit kada je nivo signala AP / Routera jak a stvar se bitno mijenja kada je kojim slučajem "na granici". Neke kartice / drajveri prekinu / izgube link a druge ga uspijevaju održavati uz neizostavno smanjenje brzine. U cijelu tu priču još dolazi koji je standard u igri (b ili g ili n).
Za kraj, pohvala za trud.
Staro 09.11.2011., 12:38   #6
Dottore
Dottore's Avatar
Postovi: 7,653
Izgleda dobro ali test je pomalo cudan.
Recimo, npr. nekada Broadcom sada pokazuje full crtu, a kojih dva sata kasnije padne na 3 crte.
Pitanje je, kako si testirao? Odsarafio si i upalio na drugom mjestu?
Imam toliko laptopa i svaki put kad pomaknem i pokazuje cudne rezultate. Kako god stanem na jednom mjestu i pomaknem 1 cm onda je full.
Ovo sto si pokazao u Windows zero connection apsolutno ne znaci nista osim testa netstumblera i inssider-a gdje moze pokazati osjetljivost kao sto spomenuo kolega Nikky. Ipak pohvaljujem za trud i predanost.
Jedna mala opaska.
Netstumbler radi na Win Xp
Inssider radi na Win Xp i na Sedmici.
Broadcom radi odlicno na zatvorenom i suhom vremenu nego Atheros na mokrom vremenu. Ralink losije radi na zatvorenom i losije na mokrom. Intelovke rade bolje i stabilnije.
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 09.11.2011., 14:10   #7
vranjba
vranjba's Avatar
Postovi: 613
testirano sve sa istog mjesta na stolu
kad uhvatim vremena isprobam sa driverima sa one stranice i sa jednim od ovih programa
PSU: Corsair cx400W
Daljnski: Mce ir
OS: Windows 7 x64
HP Compaq nx7010
HDD: wd 40 GB
OS: Win XP SP3 x32
MBO: Intel D815EFV
RAM: 2x 256mb PC133
PSU: Codegen 400W
OS: Win XP SP3 x32
Net: T-com Flat
Acernote lite 350pc
HDD: ibm 540 mb
OS: win 95
Monitor: Acer 13"
OS: dos 6.22
