Povratak   PC Ekspert Forum > Računala > Software > Web dizajn, programiranje i ostalo
Staro 30.10.2011., 19:37   #1
demo_
Datum registracije: May 2009
Lokacija: Skopje
Postovi: 56
molim pomoc sa vbulletin
Hi jer moze neko ko ima premum account na vbulletin.com da mi donwload onaj .zip file sa prvi post i posalje na i_can_just_do_it@hotmail.com ?
https://www.vbulletin.com/forum/show...rting-to-UTF-8
Hvala puno onome ko mi pomoci
demo_ je offline   Reply With Quote
Staro 01.11.2011., 14:36   #2
dal3boy
dal3boy's Avatar
Datum registracije: Dec 2010
Postovi: 90
dal3boy je offline   Reply With Quote
Staro 28.11.2011., 00:51   #3
demo_
Lokacija: Skopje
Postovi: 56
sorry malo sam dosadan...Jer moze da mi da neko printscreen od prvi post ovoga?
http://www.vbulletin.org/forum/showthread.php?t=266608
Treba mi one sakrivene delove...
Hvala puno
Staro 29.11.2011., 16:23   #4
demo_
Lokacija: Skopje
Postovi: 56
BUMP
Pls neko hitno je ?
Hvala.
Staro 02.01.2012., 16:02   #5
dal3boy
dal3boy's Avatar
Postovi: 90
sry nisam bio u HR da odg odmah...
Evo ss
http://imageshack.us/photo/my-images...enshotvqh.png/
i sve iz prvog posta
Code:
Hello guys,
Someone asked me to write this small mod for him and I decided to release it free for everybody here at vb.org.
If you are running a big board with a lot of forums. Especially someone who are using 2 column for display box in forumhome, you must meet the problems with display forum descriptions. Your layout will be look cleaner and nicer if all the box looks equal together.
This mod remove the default descriptions and only dislay it on mouse-over (similiar to xenforo).
I only use very small jquery and css to display it, then it won't do any effect to your site load.
Live demo: http://vitrastudio.com
http://www.thevbexperts.com
Screenshot: attachments
Brought to you by vitrastudio.com
Installation:
I. Add the following css in your additional.css
Code:
.tip {
    background: none repeat scroll 0 0 #1D1D1D;
    color: #FFFFFF;
    display: none;
    font-size: 11px;
    font-weight: normal;
    margin-left: 10px;
    padding: 3px 7px;
    position: absolute;
    width: 300px;
    z-index: 1000;
    -webkit-border-radius: 3px;
    -moz-border-radius: 3px;
    border-radius: 3px;
  -ms-filter: "progid:DXImageTransform.Microsoft.Alpha(Opacity=80)";
  filter: alpha(opacity=80);
  -moz-opacity: 0.8;
  -khtml-opacity: 0.8;
  opacity: 0.8;
II. Add the following code at the bottom of your headinclude template
Code:
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js"></script>
<script type="text/javascript">
$(document).ready(function() {
    //Tooltips
    $(".tip_trigger").hover(function(){
        tip = $(this).find('.tip');
        tip.show(); //Show tooltip
    }, function() {
        tip.hide(); //Hide tooltip
    }).mousemove(function(e) {
        var tipWidth = tip.width(); //Find width of tooltip
        var tipHeight = tip.height(); //Find height of tooltip
        //Distance of element from the right edge of viewport
        var tipVisX = $(window).width() - (mousex + tipWidth);
        //Distance of element from the bottom of viewport
        var tipVisY = $(window).height() - (mousey + tipHeight);
        if ( tipVisX < 20 ) { //If tooltip exceeds the X coordinate of viewport
            mousex = e.pageX - tipWidth - 20;
        } if ( tipVisY < 20 ) { //If tooltip exceeds the Y coordinate of viewport
            mousey = e.pageY - tipHeight - 20;
        //Absolute position the tooltip according to mouse position
        tip.css({  top: mousey, left: mousex });
</script>
I'm using google api for jquery but of course, you can download it and reupload it to your site.
III. Open template forumhome_forumbit_level2_post
Find the following code
Code:
<h2 class="forumtitle"><a href="{vb:link forum, {vb:raw forum}}">{vb:raw forum.title}</a></h2>
Change to
Code:
<h2 class="forumtitle"><a title="" class="tip_trigger" style="" href="{vb:link forum, {vb:raw forum}}">{vb:raw forum.title}<span class="tip"><vb:if condition="$show['forumdescription']"><p class="forumdescription">{vb:raw forum.description}</p></vb:if></span></a></h2>
Code:
Remove it
Pretty simple huh ?
If you using it on your site, please mark as installed to show your support.
More will come, I promised.
Regards,
Jeff Ledger
