Staro 07.10.2011., 13:49   #1
Chandler
Chandler's Avatar
Postovi: 225
(riješeno) Windows 7 Ultimate - IRQL Not Less Or Equal
Dakle pojavljuje se BSOD i tamo pise
STOP 0X000000D1 (0xC2887F47,0x00000002,0X00000008,0xc2887f47)
Help!!!!
Chandler je offline   Reply With Quote
Staro 08.10.2011., 21:05   #2
dino25
Kyro
dino25's Avatar
Lokacija: Poreč
Postovi: 226
Skini WhoCrashed programčić pa vidi šta ga ruši
HP Omen 17
i5 9300H
nVidia 1666 Ti
8 GB 2666
512 gb ssd
dino25 je offline   Reply With Quote
Staro 11.10.2011., 01:25   #3
Chandler
Chandler's Avatar
Postovi: 225
Evo ovako:
crash dump file: C:\Windows\Minidump\101111-13977-01.dmp
uptime: 00:24:15
This was probably caused by the following module: ntkrnlpa.exe (nt+0x415DB)
Bugcheck code: 0xD1 (0xFFFFFFFFC2A91F47, 0x2, 0x8, 0xFFFFFFFFC2A91F47)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntkrnlpa.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
crash dump file: C:\Windows\memory.dmp
uptime: 00:24:15
This was probably caused by the following module: ntkrpamp.exe (nt!Kei386EoiHelper+0x29D3)
crash dump file: C:\Windows\Minidump\100711-17456-01.dmp
uptime: 00:27:48
This was probably caused by the following module: amdk8.sys (amdk8+0x1BB6)
Bugcheck code: 0xD1 (0xFFFFFFFFE28A88B5, 0x1C, 0x8, 0xFFFFFFFFE28A88B5)
file path: C:\Windows\system32\drivers\amdk8.sys
On Thu 06.10.11. 22:39:36 GMT your computer crashed
crash dump file: C:\Windows\Minidump\100711-16692-01.dmp
uptime: 00:06:03
This was probably caused by the following module: win32k.sys (win32k+0xAAA12)
Bugcheck code: 0x50 (0xFFFFFFFFD46D5947, 0x8, 0xFFFFFFFFD46D5947, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\Windows\system32\win32k.sys
description: Multi-User Win32 Driver
Sad sam probao reinstalirati sve drivere i maknuti sve programe i izdrzao je nesto malo duze nego inace i opet ista stvar. Help!!!!
Staro 11.10.2011., 02:26   #4
gangxxxta
hustla
gangxxxta's Avatar
Postovi: 930
dali ti je komp oc-an? inace ta greska dolazi kod pretjerivanja s oc-om
I don't need to "Get a life". I'm a gamer. I have lots of lives.
gangxxxta je offline   Reply With Quote
Staro 11.10.2011., 09:28   #5
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,716
svi driveri koje je instalira sam windows updejtaj na drivere hardvera sa službenih stranica, znači matična, lan, zvuk, grafička...
Nakon toga javi da li se i dalje javlja error.
Staro 11.10.2011., 12:52   #6
Chandler
Chandler's Avatar
Postovi: 225
Driveri i jesu sa sluzbenih stranica,komp nije clockan jedino mi je nakon instalacije win7 poceo pokazivati da proc radi na 3,2 a radi se o athlonu 6000+ (3,1),neznam dali bi to bio razlog? Ili je mozda do ram-a,probao sam sa memtestom i izbacio mi je 7 errora?
Staro 11.10.2011., 13:03   #7
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,818
Autor Chandler Pregled postova
Pa ak ti baca errore na memtestu, onda ti je glavni krivac memorija..
Staro 11.10.2011., 13:45   #8
Ivo_Strojnica
PRO
Postovi: 4,716
pokušaj staviti kekse memorije u druge utore na matičnoj pa opet izvrti memtest. Ako se i tada pojave errori, onda ti je otiša RAM.
Staro 12.10.2011., 02:30   #9
Chandler
Chandler's Avatar
Postovi: 225
Probao sam staviti ram u drugi utor i istestirao sam sa memtestom koji ovaj puta nije pokazao niti jedan error i cak je i komp ovaj puta radio dosta duze nego inace ali opet na kraju kad sam se ponadao da je sve ok ono opet ista stvar;opet bsod. Sta da radim?
Staro 12.10.2011., 14:25   #10
martyn
martyn's Avatar
Lokacija: ZG Dubrava
Postovi: 121
Povećaj napon na memoriji (pod pretpostavkom da su clock i latencije na defaultnim vrijednostima) pa vidi hoće li se ponovo pojavljivati BSOD.
.........."640K ought to be enough for anybody".........
Lenovo ThinkPad X260:
i5-6300U / 16 GB DDR4 / 500 GB Samsung EVO 850 / 12,5'' 1366x768 IPS / Windows 10 Pro
ThinkPad Pro Dock: 24'' BenQ
BL2420PT 2560x1440 IPS / daskeyboard prime13 / Logitech RX1000 / Harman Kardon Soundsticks II
Pošteni, dobri i odgovorni trgovci: 1
martyn je online   Reply With Quote
Staro 12.10.2011., 20:23   #11
Chandler
Chandler's Avatar
Postovi: 225
Izgleda da je rjeseno,barem se nadam,evo komp radi cijelo popodne ja se nadam da ce tako i ostati. Problem je bio u biosu;tamo ima neka opcija amd boost koju sam iskljucio i evo da kucnem u drvo jos se nije srusio.
Hvala svima na pomoci !!!!
