Staro 22.06.2005., 12:28   #1
martin00
martin00's Avatar
Lokacija: cro
Postovi: 30
AMD konfiguracija- završna riječ
Napokon je dosao i taj dan. Drugi tjedan idem kupiti novi komp! Slozio sam ovo a vas molim da to ocijenite!
MBO DFI nF4 DAGF, nForce 4, DDR, zvuk, S-ATA, FW, G-LAN, PCI-E, s. 939 769,72
CPU AMD Athlon64 3200+ BOX, socket 939, Venice, 2000MHz, 512kb c., FSB 800MHz 1.570,19
RAM PC-3200, 1024MB, DDR, Corsair, KIT, Value Select, DDR 400 MHz, 2 x 512MB 937,99
HDD 160.0 GB SEAGATE, NCQ, 8MB cache, Serial ATA Plus 698,61
VGA PCI-E LEADTEK PX6600GT Extreme, GeForce PCX 6600GT, 128MB, DVI, TV 1.527,58
DVD ROM TEAC 16x 48x, black, DV-516D, bulk 193,99
DVD±RW PIONEER DVR-109, 16x, black, Dual layer ± recording, bulk 463,59
Modem Conexant 56k, interni, softverski 46,85
Floppy drive 3.5'', 1,44MB, crni 46,01
Monitor 19" Samsung SM997MB srebrno crni, 96 kHz, 0.20mm. DynaFlatX 1546,26
Kuciste ENERMAX Silver Wizard 3, 360W ATX 2 ver 2.0, MIDI, black, neon, pleksi 486,6
+MS Black Value Pack (MultiMedia Keyboard CRO, crni + Wheel Mouse Optical, crni) PS/2 OEM 226 kn
ukupno 8500
sve ce biti kupljeno u linksu osim tipk i misa(ve-mil)
Komp bi sluzio za igranje, mozda poneki OC(u buducnosti)…
Uglavnom, sto mislite?
martin00 je offline   Reply With Quote
Staro 22.06.2005., 13:07   #2
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Ako se ne varam ta memorija i nije baš nešto posebno,a jesi li razmišljao o x800XL...
Staro 22.06.2005., 13:25   #3
martin00
martin00's Avatar
Lokacija: cro
Postovi: 30
sto mislis o jednoj od ovih memi: (naravno X2)
RAM PC-3200, 512MB, DDR, Corsair C2, Black, DDR 400 MHz, CMX512A-3200C2 641,28 602,8 564,33
RAM PC-3200, 512MB, DDR, Corsair C2, KIT, TwinX, Black, DDR 400 MHz 641,28 602,8 564,33
koja je bolja?
za x800XL nemam para, skuplja je 800 kn
Staro 22.06.2005., 14:11   #4
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,682
uzmi si "ram pc-3200, 512mb, ddr, pqi, kit,turbo dbu,ddr 400 mhz, 2x256mb, pqi3200-512dbu 2-2-2-5" 999,21kn za cash - LINKS
tu memoriju imam ja samo što ja imam jednu pločicu od 512MB i super sam zadovoljan
Staro 22.06.2005., 14:11   #5
E.T.
E.T.'s Avatar
Postovi: 2,458
Re: AMD konfiguracija- završna riječ
ukupno 8500
-Konfiguracija izgleda OK. Ja bi eventualno izabrao druge opticke diskove recimo: DVD Toshiba 163Kn i DVD-RW NEC...
Sto se tice tipkovnice i misa IMHO bolji izbor bi bio Logitech Deluxe (samo 63Kn a odlicne tipke jedino sta nema dodatne mulimedijalne tipke) i kakav USB Logitech mis za cca 90Kn...
Sta se tice memorije ako neces oc-ati ustedi si 200-tinjak Kn i kupi A-Datu, a ako hoces dodaj 300-tinjak Kn i kupi Kingmax Hard core 500!
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 22.06.2005., 16:48   #6
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Re: Re: AMD konfiguracija- završna riječ
HC500 u trgovinama (zeleni) je
A optika (snimač), zna se-pioneer, toshibu imam, glasna je za čitanje cd-ova...
BTW, ušparaj tih 800KN za x800xl ili "suzi" konfiguraciju negdje.
Staro 22.06.2005., 19:35   #7
martin00
martin00's Avatar
Lokacija: cro
Postovi: 30
to je ukupno 512 MB(2x256), a ja bi 1 GB
dajte mi preporucite nesto od memorije do 1000 kn (moze i do 1100)
Staro 24.06.2005., 20:40   #8
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,682
ram pc-3200, 1024mb, ddr, ocz, kit, performance el, ddr 400 mhz, 2 x 512mb 2-3-2-6 = 1.175,12 KN Links
Staro 24.06.2005., 22:09   #9
martin00
martin00's Avatar
Lokacija: cro
Postovi: 30
za koliko je boji od corsairovog valuea???(skuplji je 400 kn)
Staro 24.06.2005., 22:26   #10
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
za jako puno radi na 2-3-3 koji ce u 90% ici na 2-2-2 dok kors value u 90% nece ici ni na 2.3.3
blup
mc_fish je offline   Reply With Quote
Staro 25.06.2005., 13:45   #11
E.T.
E.T.'s Avatar
Postovi: 2,458
Kao sta riba kaze to ti je odlican izbor barem sta se tice latencija...
-Recimo 2x512Mb Kngmax Hardcore DDR 500 rama ce ti raditi stabilno na 2.5-3-3-6 @500Mhz, a idu i preko tih 500Mhz no latencije neidu nize a doticni 1Gb memorije kosta 1350Kn... IMHO odlican izbor ako te nesmeta to sta nije 2-2-2 mema... neznam ja sam uvijek za "zrtvovanje" nesto latencija na stranu veceg FSB-a i samog oc procesora koji je tim veci te zahtjeva manje dizanje voltaza i jeftinije hladenje ako mu FSB ide na kakvih 250Mhz (10x250=2500Mhz ! -postigao sa Kingmax hardcoreom bez dizanja voltaze procesora (3200+) i memorije i sa Box hladnjakom s temperaturom 51 pod max opterecenjem pri sobnoj temperaturi od 27 stupnjeva a box cooler je preskakao izmedu cca1500 i 3000 okretaja sto vodi do zakljucka da bi kvalitetnijim hladenjem kucista isti radio necujno na cca 1500okretaja pri takvom oc i sta ce ti onda Zalman i sl.).
