Staro 21.06.2005., 11:07   #1
shimpa
PC Ekspert
shimpa's Avatar
Lokacija: localhost
Postovi: 1,012
Windows XP Shortcuts
evo, zahvaljujući Lord Nitro-u, imamo popis svih standardnih Microsoft hotkey-a.
ALT+- (ALT+hyphen) Displays the Multiple Document Interface (MDI) child window's System menu
ALT+ENTER View properties for the selected item
ALT+ESC Cycle through items in the order they were opened
ALT+F4 Close the active item, or quit the active program
ALT+SPACEBAR Display the System menu for the active window
ALT+TAB Switch between open items
ALT+Underlined letter Display the corresponding menu
BACKSPACE View the folder one level up in My Computer or Windows Explorer
CTRL+A Select all
CTRL+B Bold
CTRL+C Copy
CTRL+I Italics
CTRL+O Open an item
CTRL+U Underline
CTRL+V Paste
CTRL+X Cut
CTRL+Z Undo
CTRL+F4 Close the active document
CTRL while dragging Copy selected item
CTRL+SHIFT while dragging Create shortcut to selected iteM
CTRL+RIGHT ARROW Move the insertion point to the beginning of the next word
CTRL+LEFT ARROW Move the insertion point to the beginning of the previous word
CTRL+DOWN ARROW Move the insertion point to the beginning of the next paragraph
CTRL+UP ARROW Move the insertion point to the beginning of the previous paragraph
SHIFT+DELETE Delete selected item permanently without placing the item in the Recycle Bin
ESC Cancel the current task
F1 Displays Help
F2 Rename selected item
F3 Search for a file or folder
F4 Display the Address bar list in My Computer or Windows Explorer
F5 Refresh the active window
F6 Cycle through screen elements in a window or on the desktop
F10 Activate the menu bar in the active program
SHIFT+F10 Display the shortcut menu for the selected item
CTRL+ESC Display the Start menu
SHIFT+CTRL+ESC Launches Task Manager
SHIFT when you insert a CD Prevent the CD from automatically playing
WIN Display or hide the Start menu
WIN+BREAK Display the System Properties dialog box
WIN+D Minimizes all Windows and shows the Desktop
WIN+E Open Windows Explorer
WIN+F Search for a file or folder
WIN+F+CTRL Search for computers
WIN+L Locks the desktop
WIN+M Minimize or restore all windows
WIN+R Open the Run dialog box
WIN+TAB Switch between open items
Windows Explorer Shortcuts
ALT+SPACEBAR - Display the current window’s system menu
SHIFT+F10 - Display the item's context menu
CTRL+ESC - Display the Start menu
ALT+TAB - Switch to the window you last used
ALT+F4 - Close the current window or quit
CTRL+A - Select all items
CTRL+X - Cut selected item(s)
CTRL+C - Copy selected item(s)
CTRL+V - Paste item(s)
CTRL+Z - Undo last action
CTRL+(+) - Automatically resize the columns in the right hand pane
TAB - Move forward through options
ALT+RIGHT ARROW - Move forward to a previous view
ALT+LEFT ARROW - Move backward to a previous view
SHIFT+DELETE - Delete an item immediately
BACKSPACE - View the folder one level up
ALT+ENTER - View an item’s properties
F10 - Activate the menu bar in programs
F6 - Switch between left and right panes
F5 - Refresh window contents
F3 - Display Find application
F2 - Rename selected item
Internet Explorer Shortcuts
CTRL+A - Select all items on the current page
CTRL+D - Add the current page to your Favorites
CTRL+E - Open the Search bar
CTRL+F - Find on this page
CTRL+H - Open the History bar
CTRL+I - Open the Favorites bar
CTRL+N - Open a new window
CTRL+O - Go to a new location
CTRL+P - Print the current page or active frame
CTRL+S - Save the current page
CTRL+W - Close current browser window
CTRL+ENTER - Adds the http://www. (url) .com
SHIFT+CLICK - Open link in new window
BACKSPACE - Go to the previous page
ALT+HOME - Go to your Home page
HOME - Move to the beginning of a document
TAB - Move forward through items on a page
END - Move to the end of a document
ESC - Stop downloading a page
F11 - Toggle full-screen view
F5 - Refresh the current page
F4 - Display list of typed addresses
F6 - Change Address bar and page focus
ALT+RIGHT ARROW - Go to the next page
SHIFT+CTRL+TAB - Move back between frames
SHIFT+F10 - Display a shortcut menu for a link
SHIFT+TAB - Move back through the items on a page
CTRL+TAB - Move forward between frames
CTRL+C - Copy selected items to the clipboard
CTRL+V - Insert contents of the clipboard
ENTER - Activate a selected link
F1 - Display Internet Explorer Help
shimpa je offline   Reply With Quote
Staro 03.04.2006., 10:23   #2
duffy
Brum brum...
duffy's Avatar
Postovi: 586
http://support.microsoft.com/default...b;en-us;301583
Evo vam link zahvaljujuci mom legi microsoft.com : evil :
duffy je offline   Reply With Quote
Staro 21.09.2006., 11:04   #3
Pajser
Universal TooL
Pajser's Avatar
Postovi: 323
Question Pitanje
Kad smo već kod šortkatova imam jedno pitanje:
netko mi je nešto čačkao po kompu(naravno nisam ja)i sad kad hoću pokrenit Task manager, stisnem ctrl+alt+del, ali ne događa se ništa, kako da to popravim?
Pajser je offline   Reply With Quote
Staro 21.09.2006., 16:39   #4
immortal
Kernel panic
Postovi: 522
Autor Pajser Pregled postova
Probaj: start, run, gpedit.msc, User config., Administrative templates, System, Ctrl+Alt+Del options i poigraj se opcijama (stavi disable task manager na disable).
Keyboard error or no keyboard present
Press F1 to continue, DEL to enter SETUP
immortal je offline   Reply With Quote
Staro 21.09.2006., 22:21   #5
Pajser
Universal TooL
Pajser's Avatar
Postovi: 323
Autor immoRt4L Pregled postova
Ma uopće nemam te opcije tamo, čini se da je u pitanju neka gripa sa interneta,
slijedi FORMAT C:
Staro 21.09.2006., 22:25   #6
immortal
Kernel panic
Postovi: 522
slijedi FORMAT C:
To uvijek popravi takve probleme.
Staro 21.09.2006., 22:59   #7
Pajser
Universal TooL
Pajser's Avatar
Postovi: 323
Pa da nego šta, ja uopće nemam nikakvih zaštitnih programa koji ti kao štite komp od raznog smeća, a zapravo ne znaš dali ti više štete oni sami ili to smeće koje kao pokupiš. Koristim mozillu i antidialer i to je to.Dvije particije i kad zatreba samo Format C: i da vidiš kak radi.
Ovi nortoni i kojekakvi programi služe samo da usporavaju komp, a čak sumnjam da i oni proizvode te pizd...je da bi se mogli prodat.
Inače mislim da sam ovo pokupio zato što sam instalirao neki glupi programčić.
Ajd pozdrav: hello2 :
Staro 04.10.2006., 12:51   #8
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Dali si probo ovo to ti je inace kada te viroza napadne i dobijes da samo administrator moze pokrenuti task manager .
http://windowsxp.mvps.org/reg/EnableTM.reg
' alt='' border=0>
Vejita je offline   Reply With Quote
Staro 04.10.2006., 16:16   #9
ou75id32
Postovi: 153
Evo iz naftalina su se izvukli i shortcuti za windowse...
Korisno je ali nema smisla jer ako je netko toliko lijen da mu se ne da malo proći google zbog takvih stvari čisto sumnjam da mu ovo išta znači...
A kad je već tu bar će nekome uštedjeti vremena : lol2 :...
Pohvala za trud...
ou75id32 je offline   Reply With Quote
Staro 02.04.2007., 02:58   #10
Hrvoje Kusulja
Hrvoje Kusulja's Avatar
Lokacija: Zagreb, Croatia
Postovi: 12
probaj sam dal uopce mozes uc u task manager..
start> run> taskmgr
Hrvoje Kusulja
Hrvoje Kusulja je offline   Reply With Quote
Staro 02.04.2007., 11:45   #11
SPLiFF
SPLiFF's Avatar
Postovi: 2,119
Autor Hrvoje Kusulja Pregled postova
start> run> taskmgr
vjerujem da je nakom pola godine vec 3 put reinstaliro windowse
Staro 02.08.2007., 17:57   #12
Locutus of Borg
Locutus of Borg's Avatar
Lokacija: Nedaleko Osijeka
Postovi: 64
za svaki slucaj, evo jos jednog shortcuta:
CTRL+SHIFT+ESC => task manager...
Locutus of Borg je offline   Reply With Quote
Staro 23.09.2007., 22:32   #13
jabuka
destabilizator provokator
jabuka's Avatar
Lokacija: Zagrabia
Postovi: 82
imao sam isti problem sa task managerom, RMB na taskbaru i Task Manager je bio blijed i nije se moglo kliknuti na njega, FORMAT C:\ je riješio stvar
jabuka je offline   Reply With Quote
