Staro 07.08.2011., 15:04   #1
Wannabes
Wannabes's Avatar
Datum registracije: Apr 2011
Lokacija: Sk
Postovi: 188
Windows media player hide to taskbar
Winamp ima jednu finu opciju da kad se minimizira automatski se sakrije program iako radi. Znači ostane samo ikona na taskbaru u notification area.
Kak se to napravi sa Windows media playerom? Googlam ali bez uspjeha..
Koristim na XP-u WMP verziju 9.
Wannabes je offline   Reply With Quote
Staro 07.08.2011., 16:25   #2
Baja 001
Baja 001's Avatar
Postovi: 7,504
Nikako. Send to tray, traži na googleu imaš poseben toolove za to
Staro 07.08.2011., 18:35   #3
Wannabes
Wannabes's Avatar
Lokacija: Sk
Postovi: 188
Šta ću ja bez tebe.
Skinuo sam ovdje na dnu stranice Windows Media Player Tray Control 9.0 i ok radi. Recimo.
Sad ne znam jel ta zakrpa tak zamišljena (ak je onda je to kita labudova) ili se ne mogu snać ali imam isti problem kao ovaj lik...
I installed the Tray Control for WMP from the WM Bonus Pack, but it doesnt "minimize to tray" when I minimize it. Instead it goes on the taskbar as normal even with the tray control open.
In order to hide it from the taskbar i have to manually right click on the tray icon and choose "hide media player", if I left click on the tray icon, it just pauses/play the current track-it doesnt unhide the player which is what i want. Quite annoying.
