Lokacija: Vž
Postovi: 81
nForce 560 (GA-M56S-S3) i 64bit chipset driveri
Lijep pozdrav nakon duuuugo vremena, Dakle, zanima me sto mi je ciniti posto nema drivera za win 7 64bit za moju plocu? Postoji li kakva alternativa ili mozda vec win 7 ultimate N imaju u sebi set drivera koji podrzavaju nforce 560? Hvala unaprijed!
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore |
Datum registracije: Apr 2011
Lokacija: Usa
Postovi: 628
Je si li pokušao preko opcije compatibile? |
Lokacija: Vž
Postovi: 81
Nisam, samo sam probno instalirao win 7 ultimate N 64 bit na jedan stariji SATA disk da vidim kako ce to radit na mom sustavu. Radi vrlo dobro, u detaljnija podesavanja nisam ulazio ... samo sam se ugodno iznenadio koliko su win 7 inteligentniji OS od XP-a. Prelazim na njih tek nakon sto nabavim novi HDD i memoriju. Sad imam ddr2@400 sto je duplo manje od nog sto podrzava moja ploca.
