Staro 05.06.2005., 17:36   #1
Bili89
Bili89's Avatar
Postovi: 5
Problem s grafickom pixelview 6600gt
Prije tjedan dana kupio sam sljedecu konfiguraciju:
Athlon 64 3000+
Pixel View GF 6600GT PCX
Gigabyte GA K8NF-9 K8 TRITON Series
Seagate Barracuda 120 GB 7200.8
1 GB RAM-a u Dual Channelu.
Instalirao sam FarCry i nakon pola sata igranja pojavi mi se Blue Screen of Death sa greskom
A problem has been detected and Windows has shut down to prevent damage to your computer.
The problem seems to be caused by the following file: nv4_disp
If this is the first time you've seen this Stop error screen, restart your computer. If this screen appears again, follow these steps:
The device driver got stuck in an infinite loop. This usually indicates problem with the device itself or with the device driver programming the hardware incorrectly.
Please check with your hardware device vendor for any driver updates
Technical Information
*** STOP: 0x000000EA (0x81A10A00, 0x82208008, 0x81A1CAD8, 0x00000001)
nv4_disp
Beginning dumb of physical memory.
Physical memory dumb complete.
Contact system administrator or technical support group for further assistance.
Sada razmisljam da uzmem drugu graficku,moze li mi netko pomoci?
Zadnje izmijenjeno od: Bili89. 05.06.2005. u 17:49.
Bili89 je offline   Reply With Quote
Staro 05.06.2005., 17:40   #2
Trek
Trek's Avatar
Postovi: 1,313
jel ti grafa ima dodatno napajanje?
Biti lud ima prednosti koje razumiju samo ludjaci
FKT meber jednog dana high priest...
Trek je offline   Reply With Quote
Staro 05.06.2005., 17:44   #3
Bili89
Bili89's Avatar
Postovi: 5
U kucistu mi se nalazi napajanje codegen 480W
Staro 05.06.2005., 17:47   #4
Trek
Trek's Avatar
Postovi: 1,313
ajoj... mislim da ti napajnje mozda nedaje dosta struje, al za taj codegen 480W sam cuo da i nije tak strasno los.
aj probaj ovak, stavi najnovije drivere i odvrti 3d mark neki pa reci dal se on rusi.
Staro 05.06.2005., 17:55   #5
Bili89
Bili89's Avatar
Postovi: 5
Ma nemogu instalirat najnovije drivere jer mi dolazi onaj error, instalirao sam orginalne drivere i opet isto,flashirao sam bios za maticnu a za graficku nisam pronasao bios,bio sam i ponovo instalirao windowse,tri puta,a opet isti problemi,sad namjeravam uzeti novu graficku Gainward Ultra/1960 XP, GF 6600GT PCX,sta mislis o svemu???
Staro 05.06.2005., 18:09   #6
Trek
Trek's Avatar
Postovi: 1,313
pa nemoj odma kupovat novu grafu. prvo, provjeri dal ti je unutra sve pospajano dobro, odnesi grafu onda na servis i trazi novu.
Staro 05.06.2005., 18:13   #7
Bili89
Bili89's Avatar
Postovi: 5
Ma vec mi je bila graficka na servisu,oni su rekli da nesto s grafickom nije uredu i dali mi novu, kad ono s njom isti problem pa tako da neznam dal da uopce uzmem nvidijinu nego neku atijevu.Sta ti kazes Ati ili Nvidia??????
Staro 05.06.2005., 18:39   #8
Trek
Trek's Avatar
Postovi: 1,313
a mozda ti je ploca zmrdana? probaj neko drugo napjanje
Staro 05.06.2005., 19:15   #9
Bili89
Bili89's Avatar
Postovi: 5
Ma nije do napajanja.problem se pojavi kad instaliram drivere za graficku.
Moguce je jedino da se maticna i graficka nekako "ne podnose",pa me zato izbacuje
Staro 08.06.2005., 03:11   #10
kresimirSM
kresimirSM's Avatar
Lokacija: Dubrovnik
Postovi: 118
Stari fakat bi volio pomoc ali nazalost nemam pojama....pa se nemoj ljutit!
HAHAHAHAHAH SALA LOL !!!!
nemoj se ljutit!
kresimirSM je offline   Reply With Quote
Staro 08.06.2005., 09:42   #11
mimi
mimi's Avatar
Postovi: 25
Uvijek sam za Ati prije nego nvidija.Uzeo sam gforce3 nikako je nism mogao instalirati pa sam je otišao zamijeniti zaVGA SAPPHIRE ATI Radeon, 9600 PRO ADVENTAGE 128 bit.256 MB ,instaliro bez greške i radi ko urica,ati je jeftiniji bolji i jednostavniji.
Pivkan
mimi je offline   Reply With Quote
Staro 08.06.2005., 12:35   #12
Američanac
Američanac's Avatar
Datum registracije: May 2003
Lokacija: Metropola
Postovi: 156
Kupio si komp, sad moraš učit
Lekcija broj 1:
Kad kupiš "gotovo" računalo, odnesi ga nekom tko zna to isto i upogoniti.
Prvo otvoriti komp, poslagati kartice kako bog zapovijda, fleshati BIOS da se maknu sranja iz memorije dok su ga "testirali", podesiti isti, reparticionirati disk na kvalitetni NTFS sa recimo 32/64 K clusterima, instalirati OS, instalirati u pravilnom redosljedu chipset, VGA, direct X i ostale drivere, maknuti sve fičure sa windows XP-a, pogasiti tebi nepotrebne servise, preporučiti zaštitu i naučit te kako se koristi i tek onda nećeš imat problema ili ukoliko se za vrijeme procedure nešto zblesira nositi na reklamaciju.
99% prodavača u Hrvatskoj su ipak samo prodavači kao što su to i one kumice na placu: nemaju vremena za takve stvari između servisa i nošenja kutija.
Kad savladaš lekciju br. 1, lekcija br. 2 je dijagnostika kvara ili ponovi lekciju br. 1
Kome se žuri - nek ide pješice
Trenutni hobi:
Klub IO
Američanac je offline   Reply With Quote
Staro 19.06.2005., 21:51   #13
dmd-0
dmd-0's Avatar
Lokacija: /
Postovi: 592
Re: Problem s grafickom pixelview 6600gt
Athlon 64 3000+
nv4_disp
Jeli ista oc-ano - ja sam dobivo neku sličnu poruku kad bi oco svog celera na 3GHz bez povisivanja voltaže, no buduci da sam povisio volt ne dobivam tu poruku
dmd-0 je offline   Reply With Quote
