Staro 17.05.2011., 16:58   #1
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
Nvidia Forceware v275.27 beta driveri
This is the first release from the Release 275 family of drivers (versions 275.xx to 279.xx). You can read more about this family of drivers on GeForce.com.
This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, 400, and 500-series desktop GPUs as well as ION desktop GPUs. This driver package also includes the 3D Vision Controller driver.
New in Release 275.27
GPU Support
Adds support for the newly released GeForce GTX 560 GPU.
Performance
Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v270.61 WHQL drivers. The following are some examples of improvements measured on Windows 7. Results will vary depending on your GPU and system configuration:
GeForce GTX 580:
Up to 4% in Crysis 2
Up to 5% in Civilization V with SLI
Up to 9% in Portal 2
Up to 13% in Bulletstorm with Antialiasing enabled
Up to 15% in Batman: Arkham Asylum with PhysX High
GeForce GTX 560:
Up to 6% in Crysis 2
Up to 8% in Portal 2
Up to 14% in Batman: Arkham Asylum with PhysX High
Up to 15% in Bulletstorm with Antialiasing enabled
Najzanimljivije:
Increases gaming performance by up to 12% for dual-core CPUs in CPU-limited cases.
Win7 64bit:
http://www.nvidia.com/object/win7-wi...ta-driver.html
Win7 32bit:
ostali:
http://www.nvidia.com/Download/Find.aspx?lang=en-us
Staro 18.05.2011., 11:01   #2
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,837
Neka, barem se trude ovi čudaci u Nvidiji. Ja ću ipak pričekati službenu verziju, za sada mi je zadnja verzija odlična.
Staro 18.05.2011., 19:39   #3
Astral
Postovi: 2,523
fora ovo zvuci za cpu, valjda nije samo jos jedan od marketinskih trikova
btw pci_e3x, za boga miloga nije valjda da ozbiljno imas ms 400w na tu konfu lol
Astral je offline   Reply With Quote
Staro 18.05.2011., 20:56   #4
Antiša
Datum registracije: Dec 2010
Postovi: 147
Fermi arhitektura je poznata po problemima sa nekim starijim CPU-ovima (prvenstveno C2Q i C2D, i stari Phenomi I). Kartice znaju imati nizak GPU Load i time očajne perfomanse. Valjda su poslsuaju jauke na sluzbenim forumima pa su sada malo poradili na tome, pa navode kao changelog.
Antiša je offline   Reply With Quote
Staro 19.05.2011., 00:40   #5
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
Autor Astral Pregled postova
nažalost iman, a još, najgore odsvega, staro je 4 godine.
nadan se da ću bit u mogućnosti nabavit neko kvalitetno. Gledat cu da ima 550W+, 2x8pin PCI-E, 5+ onih za sata diskove, 8pin za cpu
ispod toga nenabavljam :P
tako da će mi tribat dobrin love, a bio san se ponada osvojit na nagradnoj igri sta je bila ovdje
edit: sorry na OT
Staro 20.05.2011., 11:53   #6
Nick7
Lokacija: Velika Gorica
Postovi: 1,537
Iskreno, ne vidim problem sa 400W na toj konfi....
Staro 20.05.2011., 13:02   #7
Astral
Postovi: 2,523
masni OT, al eto nek se obrise ako je problem
@Nick7, nije uopce problem u 400w, problem je u MS industrial napajanju za koje se zna da je bolje da imas neko no-name nego njih
super da drzi, mora da se zalomio neki "bolji" primjerak
Staro 24.05.2011., 16:22   #8
Viperus
Viperus's Avatar
Postovi: 729
Meni naravno installer izbaci error XD
Viperus je offline   Reply With Quote
Staro 24.05.2011., 19:20   #9
DiTech
DiTech's Avatar
Postovi: 346
NVIDIA Update
In Release 275, NVIDIA Update adds automatic SLI, multi-GPU, and antialiasing (AA) profile updates. These profile updates are automatically downloaded from NVIDIA and silently installed on your PC, keeping it up-to-the-minute with the latest game profiles. When you install a Release 270 or later GeForce driver from www.nvidia.com, you will be presented with the option to install NVIDIA Update. Click here to learn more about NVIDIA Update.
DiTech je offline   Reply With Quote
Staro 24.05.2011., 21:57   #10
Sinac
Sinac's Avatar
Postovi: 2,837
Već i prethodna 270 verzija ima mogućnost provjere i instalacije novije verzije drajvera. Vidi HELP/UPDATES ako imaš 270 verziju.
Staro 25.05.2011., 14:45   #11
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
Jel poželjno kod instalacije novih drivera čistit sweeperom pa na čisto stavljat, ili samo preko starih?
Staro 25.05.2011., 14:49   #12
Sinac
Sinac's Avatar
Postovi: 2,837
Kod Nvidie funkcionira sistem da samo pregaziš staru verziju s novom.
