Staro 28.05.2005., 09:00   #1
Black Dragon
Black Dragon's Avatar
Lokacija: Agram
Postovi: 2,982
VIA 4in1 5.00 Pro
Eto pa kako se i dalje tvrdi za starije chipsete je najbolji VIA 4in1 4.43 a za nove što noviji Eto i novi samo što sada postoji i pro koji se od 4in1 bez pro razlikuje u tri glavne stvari a i niže su pobrojane novotarije:
There are three main differences between a VIA Hyperion 4in1 driver package and a VIA HyperionPro package, detailed below. All other recommendations remain.
1) The HyperionPro package includes SATA/RAID drivers whilst the Hyperion 4in1 package does not. The extra contents makes the HyperionPro package over 5MB larger than the Hyperion 4in1 package. Therefore if you are not utilizing a VIA SATA or RAID controller in your system, the Hyperion 4in1 package may be a better download choice.
2) The HyperionPro package supports 64 bit Microsoft Windows XP and 64 bit Windows Server 2003 whilst the Hyperion 4in1 package only supports 32 bit operating systems.
3) The HyperionPro package does not contain the IDE Filter driver. For Win9X/ME/2K the IDE filter driver is needed to support UDMA 6. The IDE Filter driver is not needed for WinXP SP1 and later Microsoft operating systems.
Version 500A of the HyperionPro package includes the following driver components:
INF 2.40b
AGP 4.43h
RAID V4.30c
RAID tools V4.06.
The latest version of the Hyperion 4in1 driver package includes AGP driver version 4.43f. The difference between the drivers is that 4.43h does not overwrite the default driver under Server2003 SP1.
http://downloads.viaarena.com/driver...nPro_V500A.zip ima za skinuti 6630 KB
Staro 12.07.2005., 00:32   #2
Emissary
ČLAN FKTa
Emissary's Avatar
Datum registracije: Jul 2004
Postovi: 2,264
Šta sad, da idem na to ili ne?
KT 600 je u pitanju.
Staro 12.07.2005., 02:05   #3
Black Dragon
Lokacija: Agram
Postovi: 2,982
K7 chipsets: KT400, KT400A, KT600, KT880, KM400, KN400
K8 chipsets: K8T800, K8T800Pro, K8M800, K8T890, K8T890Pro
P4 chipsets: P4X400, P4X400A, PT800, PT880, PM800, PM880, PT880Pro, PT894
4.56v je za te ali mislim da slobodno možeš i 5.00A
Staro 12.07.2005., 05:23   #4
Emissary
ČLAN FKTa
Emissary's Avatar
Postovi: 2,264
Sad sam na 4.53.
Staro 17.07.2005., 16:12   #5
tihomir
tihomir's Avatar
Datum registracije: Jan 2002
Lokacija: ?
Postovi: 2,274
Šta je s MVP3? Al ozbiljno...
tihomir je offline   Reply With Quote
Staro 17.07.2005., 20:23   #6
Black Dragon
Lokacija: Agram
Postovi: 2,982
4in1 4.43v ako ne i 4.35v ... mada idi na ziher i 4.43v ...
