Staro 14.03.2011., 15:37   #1
croclocker
croclocker's Avatar
Datum registracije: Apr 2008
Lokacija: GER
Postovi: 724
Ne mogu otvoriti Task Manager
Bok, imam problem s task managerom
stisnem ctrl alt del i ne otvori se nego pise Task manager has been disabled by the administrator
instliro sam xp na netbook ima 10ak dana i tek sad primjetio ovo
croclocker je offline   Reply With Quote
Staro 14.03.2011., 15:58   #2
nino
nino's Avatar
Postovi: 12,613
Paaa, google kaze:
Method 1
Click Start, Run and type this command exactly as given below: (better - Copy and paste)
Code:
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableTaskMgr /t REG_DWORD /d 0 /f
Method 2
* Click Start, Run and type Regedit.exe
* Navigate to the following branch:
HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
* In the right-pane, delete the value named DisableTaskMgr
* Close Regedit.exe
Method 3: Using Group Policy Editor - for Windows XP Professional
* Click Start, Run, type gpedit.msc and click OK.
* Navigate to this branch:
User Configuration / Administrative Templates / System / Ctrl+Alt+Delete Options / Remove Task Manager
* Double-click the Remove Task Manager option.
* Set the policy to Not Configured.
Staro 14.03.2011., 16:18   #3
croclocker
croclocker's Avatar
Lokacija: GER
Postovi: 724
googlo sam bio, naso nesto al nije uspjel, ne znam sto sam krivo radio
P.S. thx evo radi
EDIT
Kar se komp ugasi i opet upali ili resetira opet task manager ne radi
Zadnje izmijenjeno od: croclocker. 14.03.2011. u 19:30.
Staro 14.03.2011., 20:00   #4
RisingPower
čudovište
RisingPower's Avatar
Postovi: 757
Bilo bi dobro da prvo proskeniraš gamad... Takve peripetije su često njihovo maslo...
Failure is always an option.
RisingPower je offline   Reply With Quote
