Administrator
Lokacija: Sesvete
Postovi: 15,964
Ovo ti sigurno radi: MapKeyboard is very easy to use. Select the key you want to remap and using the Remap selected key to drop down, select the new key. Using the application, you can also map your mouse buttons. You can also disable any key you want. A probaj i ovo: http://webpages.charter.net/krumsick/ http://www.autohotkey.com/ |
#3 | |
Lokacija: Near
Postovi: 416
Da vidimo ove ostale. |
Lokacija: Near
Postovi: 416
