Staro 01.03.2011., 16:31   #1
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,144
Nvidia ForceWare 267.24 & 267.26 beta driveri
nove BETE:
http://forums.guru3d.com/showthread.php?t=339763
http://forums.nvidia.com/index.php?s...ic=194310&st=0
This is a beta driver release from the Release 265 family of drivers (versions 265.xx to 269.xx). You can read more about this family of drivers on GeForce.com.
This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, 400, and 500-series desktop GPUs as well as ION desktop GPUs.
New in Release 267.24
Adds 3D Vision support for Bulletstorm.
Adds SLI support for Homefront.
Improves compatibility with Dragon Age II.
Fixes an issue where the NVIDIA control panel may not be accessible via the Windows desktop.
Other
Installs HD Audio driver version 1.1.13.1
Installs PhysX System Software to version 9.10.0514
Users without US English operating systems can select their language and download the International driver here.
267.26 only support the GTX 560 Ti
unfortunately for all you 560 owners who are using an older card for PhysX, this driver is not 560 compatible, you will have to get 267.26 instead
Zadnje izmijenjeno od: geronimo_2. 01.03.2011. u 16:36.
