Staro 15.02.2011., 21:46   #1
Liquid Snake
Liquid Snake's Avatar
Postovi: 166
Catalyst 11.2 Official
Na serveru:
AMD Catalyst 11.2 Win 7 | Vista (64-bit)
AMD Catalyst 11.2 Win 7 | Vista (32-bit)
AMD Catalyst 11.2 Win XP (64-bit)
AMD Catalyst 11.2 Win XP (32-bit)
Code:
Driver Packaging Version            8.821-110126a-112962C-ATI
Catalyst™ Version                   11.2
Provider                            ATI Technologies Inc.
2D Driver Version                   8.01.01.1123
Direct3D Version                    7.14.10.0812
OpenGL Version                      6.14.10.10524
Catalyst™ Control Center Version    2011.0126.1749.31909
Release Notes:
http://support.amd.com/us/kbarticles...easeNotes.aspx
Dreaming in digital. Living in realtime. Thinking in binary. Talking in IP.....Welcome to our world.
~DI
Liquid Snake je offline   Reply With Quote
Staro 15.02.2011., 21:51   #2
izzi
izzi's Avatar
Postovi: 10
jer ko probao instalirat 11.2 drivere
ako nije problem da napiše dal su fixali bug sa 2d clock
izzi je offline   Reply With Quote
Staro 15.02.2011., 21:54   #3
Liquid Snake
Postovi: 166
Autor izzi Pregled postova
Ja sam ih stavio i nemam 2D clock bug, niti sam ga imao sa 11.1.
~DI
Staro 15.02.2011., 21:59   #4
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,487
mislim da mi je u idlu grafička nešto toplija (isti clock kao prije)
Staro 15.02.2011., 22:12   #5
Liquid Snake
Postovi: 166
Prakticki su isti kao i Hotfix 11.1a, samo sto su ovi WHQL i OpenGL driver je nesto noviji.
~DI
Staro 15.02.2011., 22:43   #6
izzi
izzi's Avatar
Postovi: 10
imam radeon 6870
catalyst 10.2 idle clocks 100/300
11.1 300/300
11.1a 300/300
11.2 300/300
friško instalirani windowsi
dal je to bug ili nešto drugo
hvala unaprijed
Staro 15.02.2011., 22:55   #7
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
To se i meni dogadalo sa 6850.Vjerovatno bug drivera, no nist strasno.
Staro 15.02.2011., 23:52   #8
Starsailor
Starsailor's Avatar
Datum registracije: Jan 2011
Lokacija: CRO
Postovi: 219
Mogu ih instalirati preko starih ili treba brisati stare?
Starsailor je offline   Reply With Quote
Staro 16.02.2011., 00:05   #9
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,487
po volji, ja uvijek u safe modu driver sweeperom očistim stare, ali nije nužno.
Staro 16.02.2011., 09:24   #10
gustetic
Lokacija: VG
Postovi: 67
imam radeon 6870
11.1 300/300
11.1a 300/300
11.2 300/300
hvala unaprijed
Same here ATI 6850, i stvarno mi ide na živce.
gustetic je offline   Reply With Quote
Staro 16.02.2011., 11:52   #11
Thermaltake
1
Postovi: 3,601
Kod mene od zadnje nadogradnje još uvijek ne radi catalyst imam hd 3850 agp i skinuo sam onaj driver sa hotfixom probo sve žive cleanere detaljno očistio registry ručno i dalje catalyst se neće upalit vidim u tasku da on upali MOM i CCC i budu malo upaljeni i onda se ugase iz nekog razloga,probo sam čak i starije drivere isto ništa od catalysta, a na driverima od 10.12 pa na više imam nekih problema ko recimo kad prelazim sa mišem preko X gumba za ugasit prozor onako miš počne legat prečudno, pa sam vratio na 10.11 i na njima sve ok radi samo catalyst ne.
Staro 16.02.2011., 13:58   #12
Liquid Snake
Postovi: 166
Stavio si ove AGP Hotfix drivere ?
http://support.amd.com/us/kbarticles...AGPHotfix.aspx
~DI
Staro 16.02.2011., 14:29   #13
Thermaltake
1
Postovi: 3,601
Autor Liquid Snake Pregled postova
Da to sam i napisao u prvom postu samo sa ovim zadnjim driverima imam nekih problema pa sam ostao na onim koji su mi radili dobro (10.10) znači bez onog gore problema kojeg sam opisao.Meni se display driveri uredno instaliraju i oni rade, a catalyst se instalira i ne želi se startat.
Staro 16.02.2011., 14:38   #14
nino
nino's Avatar
Postovi: 12,613
NetFramework je najcesci uzrok da CCC ne radi.
Staro 16.02.2011., 14:39   #15
Liquid Snake
Postovi: 166
Koji OS imas i koju verziju NET Framework-a ?
~DI
Staro 16.02.2011., 14:41   #16
Thermaltake
1
Postovi: 3,601
Windows 7 ultimate 32bit net freamwork sa win 7 dođe već 3.5.1 ,a ja imam još i zadnju 4-u i 1.1 instaliranu.Probo sam uninstall pa opet instalirat četvorku i dalje ništa.
Staro 16.02.2011., 16:13   #17
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Radi samo sa dvojkom
Staro 16.02.2011., 16:16   #18
Thermaltake
1
Postovi: 3,601
Kako mi je onda prije normalno radio ?
Staro 16.02.2011., 17:07   #19
Liquid Snake
Postovi: 166
Windows 7 ima po defaultu NET Framework 3.5.1 koji ukljucuje NET Framework 2.0 SP, 3.0 SP i 3.5 SP.
Anyway, ajde prodi sa Verification Tool-om da ne bi bilo nekih gresaka:
http://blogs.msdn.com/b/astebner/arc...3/8999004.aspx
~DI
Staro 16.02.2011., 17:28   #20
Thermaltake
1
Postovi: 3,601
Svi su prošli osim verzije 1.1 pa sam ju uninstaliro pošto sve šta imam na kompu ne koristi više 1.1 verziju, tako da ako nju ne računamo svi su prošli, čini mi se da verzija 1.1 nije imala veze s tim. Dali možda znaš u servisima koji procesi moraju biti upaljeni da bi catalyst uopće mogo startat? Jel ja sam neke procese disejblo, al mi je i dalje catalyst radio dok nisam htio ić noviju verziju drivera instalirat i od tad mi više ne radi, a sve sam probo sa cleanerima sa registry cleanerima u safe modu, čak sam i ručno pretražio registry i obriso neke ati i amd stvari i dalje niš.
Zadnje izmijenjeno od: Thermaltake. 16.02.2011. u 17:49.
Staro 16.02.2011., 18:28   #21
Liquid Snake
Postovi: 166
Ajde probaj jos jednu stvar, deinstaliraj samo Control Center, restartaj komp, pa instaliraj ovaj CCC:
https://a248.e.akamai.net/f/674/9206..._ccc_lang3.exe
~DI
Staro 16.02.2011., 20:26   #22
Thermaltake
1
Postovi: 3,601
Sve sam napravio ko šta si reko pokrenem i u meniju mi uopće ne ponudi catalysta, samo drivere,ati manager & visual c++ 2010.
EDIT:
format mi nikako nije opcija.
Zadnje izmijenjeno od: Thermaltake. 16.02.2011. u 20:40.
Staro 16.02.2011., 20:38   #23
bAKa-47
Postovi: 157
i ja sam imao isti problem...sve sam probo nije pomoglo. Nakraju sam napravio format c:. Znam da i nije neko rjesenje. Ako ti se neda probaj još kemijat. Mislim da mi je to bilo sa 11.10 driverima dok sam imao 4870.
Zadnje izmijenjeno od: bAKa-47. 20.02.2011. u 15:26.
bAKa-47 je offline   Reply With Quote
Staro 16.02.2011., 21:22   #24
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Dali se vama spustaju u 2D taktovi kod OCa ili su stalno na 3D?
Staro 20.02.2011., 15:11   #25
Thermaltake
1
Postovi: 3,601
Jel zna netko još možda il je imao sličan problem ko ja gore šta sam opiso pa da ga je riješio možda da mi kaže.
Staro 20.02.2011., 18:14   #26
Starsailor
Starsailor's Avatar
Lokacija: CRO
Postovi: 219
Ovi driveri su za 6870 lošiji od starih, background gifovi steam menija recimo, ovi ih prikazuju loše, nekako isprekidano, ono kao kad se raširi mala slika pa se dobije što se dobije. Dok ovi prijašnji recimo oni su prikazivali normalno te neke background gifove.
Da ne govorim da su mi addon mape l4d2 u rozim bojama sa kvadratima umjesto neba.
Ali hdmi je fixan, pucanje slike na tv je fixano, dosta bolje izgleda sada.
Staro 20.02.2011., 18:18   #27
izzi
izzi's Avatar
Postovi: 10
napisao sam ticket u vezi 2d clockova zasto nije vise 100/300 nego 300/300 na sapphire support stranici ovo sam dobio kao odgovor:
Dear Sir
It's AMD new idle clock setting, no worry for this.
Regards
Staro 21.02.2011., 17:55   #28
2 die 4
2 die 4's Avatar
Postovi: 2,276
Dear Sir
Regards
E to se zove odgovor!
Ma molim te, pa nek si nabiju to u ono mjesto od kud im izlaze te glupe ideje!
Užas, mislim da nisu imali adekvatan odgovor pa su jednostavno to napisali!
RedGreenBlue
Staro 26.02.2011., 13:44   #29
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
pozz, imao sam prije catalyst 10.8. i danas updateao na 11.2. i instalacija prođe ok a kad se restarta komp i ponovno podigne sustav 1 min radim u windowsima (win 7 64 bit) pojave mi se artifakti posvuda po malo i smrzne mi se komp...isto tako sa 11.1. vratio sam stare drivere i sve ok radi...ima li nesto sto sam propustio?
gbijelic je offline   Reply With Quote
Staro 26.02.2011., 14:05   #30
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,487
jesi očistio driver sweeperom drivere u safe modu?
